Question about Lexmark E260dn Laser Printer
All the lights are blinking on my Lexmark e260 and it will not print. I continue to get the error message and the printer continues to run. what to do
IB4G2008
  • 3587 Answers
SOURCE: lexmark x1270 printer power button blinking won't print
unplug the printer from wall and computer..let it sit for 5 min, reconnect power only. run test page first..then plug in computer..
make sure that the paper run is completely open, by opening all the panels and doors that can be.
Posted on Feb 26, 2008
  • 3 Answers
SOURCE: paper feeder won't follow through
I found olasNick's comments very worthwhile. I was also having a paper feed problem and carefully disabled my LEX73 and now clearly understand the comments regarding prying it apart. There are plastic clips that hold all of the plastic together, by gently prying and pushing the clips at the same time I was able to get it apart without breaking any plastic. Once inside the problem was obvious, a broken gear on the roller assembly. I guess I could order a new gear from LEX but at this point, I think I'll take it a sign to retire this old workhorse. I think I got this printer about 10 years ago and can't imagine how many reams of paper have gone through this printer. It doesn't owe me anything.
Posted on May 28, 2008
  • 214 Answers
SOURCE: Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
Posted on Jul 02, 2008
IrishDruid
  • 2712 Answers
SOURCE: Lexmark X6570 printer - Cleared
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Nov 11, 2008
  • 300 Answers
SOURCE: I have a Lexmark T632
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Posted on Dec 10, 2008
All lights on the printer display lit why I work in order to return to normal and what is the imbalance
If all lights are blinking, this is an indication that the printer is detecting a service error. Please press the continue button to the get secondary code indication. After pressing the continue button, please note which lights remain lighting up or blinking. For further information, please feel free to contact our Technical Support Hotline.
Dec 16, 2012 | Lexmark E260 Laser Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
My Lexmark printer is showing 122.03 service fusher error what can i do
This error normally requires a service call. However, certain rare occurrences, such as a a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 122.03 error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to test this.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
Contacting Lexmark
Please contact Lexmark Technical Support for additional assistance.
Jun 10, 2011 | Lexmark X543dn Laser Color All-In-One...
Lexmark e260d printer 4th light orange is continuously flashing. New toner cartridge was installed. Not printing
If the blinking light is on Toner Low (4th light starting from left), press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please contact Lexmark Technical Support
May 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Lexmark E260dn toner light is still on after changing the toner cartridge
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
Apr 12, 2011 | Lexmark E260dn Laser Printer
E260 laser printer.....all lights blinking.........service error....what to do? pls help.
Press Continue twice to see the secondary code. The secondary code will indicate where to locate the problem.
For further assistance, please contact Lexmark Technical Support.
Mar 23, 2011 | Lexmark E260 Laser Printer
All of the lights are blinking in unisom and the printer ill not print
If all lights are flashing, it indicates an error on the printer. Please press the continue button to see the secondary error code. The secondary code will indicate the another light sequence indicating specific problem on the printer.
Jan 12, 2011 | Lexmark E232 Laser Printer
Prints one or to pages then stops. Have to reset computer to get it to work. No test doesn't work. It is like it runs out of memory.
Try to run a test for continuous print test page in diagnostics mode. To enter the Diagnostics mode:
1. Turn off the printer.
2. Open the front access door.
3. Turn on the printer while pressing and holding Cancel .
4. Close the front access door once the Error light displays. Print the menu page by pressing and holding Continue until all of the lights flash. Follow the instructions on
the menu page to access the menu items.
Continuously print pages containing cross lines, printer information, and margin settings. Press and hold until the Continue button lights flash to begin. Press Cancel to stop.
Make sure he selects the "Cont Prt Simplex Tray 1" option
If problem persists, contact Lexmark at 1-800-LEXMARK()1-800-539-6275.
Apr 21, 2010 | Lexmark E260dn Laser Printer
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Lexmark E260dn Laser Printer Logo
644 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
