Question about Kenmore 500 6952 Dryer
Hi - I have a 500 series Gas machine that willl not start. I can hear the timer clicking but it wont start.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Will not spin to high some times and dryer just clicks and will not start
Hello & Welcome to FixYa
The click that you hear comes from dryer when either the Thermal fuse or the Timer is bad. If you hear this click from the rear panel then it is the Thermal fuse that is bad, if the click is coming from the control then Timer motor needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 20, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Pool Heater igniter wont light
Hi check out the power phile should be between 300 to 500 mille volts
Jul 11, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Kenmore 500 series gas dryer-timer doesnt turn ,wont shut off
I can locate a replacement timer and assist you with replacement if you want to replace it yourself
Apr 15, 2009 | Dryers
Kenmore 80 series washer wont spin
Sounds to me like you may have a lid switch bad. If you close the lid and don't hear that click then you can be sure that you have a bad lid switch. If it is bad your machine is thinking that your lid is up and so it won't do any washing or spinning. Replace the lid switch.
Apr 11, 2009 | Washing Machines
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Dryer wont run
Well most gas dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting. So first of all you may check out the fuse.
Good Luck!!
Thanks for using FixYa!!
Jan 11, 2008 | Kenmore Dryers
Kenmore 500 6952 Dryer Logo
102 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
