Question about Neff 23 in. T4343 Electric Cooktop
The glass cover to the large oven interior light has broken,can you help?
  • micky120528 Sep 09, 2010
    It is a Neff double oven model number 1057,large circotherm oven at top, lower conventional electric oven houses the grill.
  • 944 Answers
Please specify the oven brand name and model No so i will help you with it more easily.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 09, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 09, 2010
    You have to fully disassemble the Oven front door and remove the grill.Now you can easily reach the oven interior light bulb.Some screws will be given along with washer you have just fix the cover and screw it.
    I have not dealed with NEFF double oven but in Bosh double oven and NEFF normal oven we fit the cover glass from the backside of the oven.At the backside you could see some connection going exactly to the interior bulb.You can just unscrew from backside and remove it and fit the glass cover and place it in from the back side and screw it.In some cases we need to disassemble the full oven to reach the bulb.
    Glass cover with bulb
    have a nice day:-)
How do I change the internal lightbulb?
Your owner's manual should show how. No manual, try manualslib.com
My old sears microwave light bulb is in the upper front left hand with bulb top up and socket down but behind a screen. There are screws to remove the upper fan apparatus, which appears to make the side available to extract the bulb. Probably a very special bulb, so I would get one before going to that trouble. It might also be the switch that is bad rather than the bulb. That probably requires removing the outer surrounding cover.
Apr 11, 2015 | LG LMVH1750ST Over-the-Range Convection...
Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
Simpson fabulous 400 oven
best to measure the the hole size and then go and see a glazier for him to cut you a new heat treated piece.
Jan 18, 2014 | Jenn-Air Cooktops
Looking to replace a broken glass covertop for a Magnetic Induction hob
I looked up your cooktop and discovered it to be made by Frigidaire.
Hence & therefore, try the website "searspartsdirect" and see of they will give you schematics to buy the parts for your needs.
God bless your efforts.
Mar 06, 2018 | Sunpentown Cooktops
Broken ceramic top
hi...no nid to replace the ceramic top,coz it is very expensive compare to buy a new one.the price of the glass ceramic top is mostly half or 3/4 of the actual price of the new one.much beter to buy an new one,get an new & the warranty but the glass is not covered in waranty for all brand.
Sep 10, 2009 | Cooktops
I have kenmore ceramic top range model number 79096011407, the glass top is cracked and I want to replace it but don't know how it comes off the manual is lost. There are three screws above where the oven...
are u sure u want to replace the ceramic glass top,much beter to check the price of the unit, coz it is very expensive almost halt the price of the new one...dont try to replace it by ur self coz the glass cover is no waranty if u broke or wrong intallation,u waste ur money if hapen that,much beter to canvas first & call an expert tecnician to do it.
Sep 08, 2009 | Cooktops
Have broken the glass on a new world hotplate unit. Hotplate number CKG 21822. G.C No 11.641.19. G.C No 079513 cover top assembly brown part number 931337000. Hotplate unit is ok but require a replacement...
hi...first thing to do is canvas the price of the ceramic glass top,coz the price of the glass is half or more compare to the new one..do u think if u buy a glass only it is reasonable or waste ur money?then dont try to fix it by it ur self,coz the glass u buy is no warranty for wrong instalation.call an expert technician to do it to get an assurance for the warranty for installation.
Sep 07, 2009 | Cooktops
Large section of dual burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jul 07, 2009 | GE 30 in. Profile JP989 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
OVEN BULB COVER
It should just turn counterclockwise to come off.  Sometimes it is very hard to turn them.  If you have a strap wrench you could try that.
Oct 19, 2007 | Cooktops
Neff 23 in. T4343 Electric Cooktop Logo
100 people viewed this question
Top Neff Cooktops Experts
Samyfam
Samyfam
Paul Carew
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
