Question about Whirlpool Dryers
The motor and blower work fine - no heat - Whirlpool Dryers
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
Why did my front heat blower stop working?
front blower motor went bad if the fuse is ok
my blower motor resistor also went bad
(happened to me)
Mar 26, 2015 | 2008 Chrysler Town & Country
Heater won 39 t blow on 5
haw i fix my rpm meter problem
Sep 28, 2013 | Cars & Trucks
No heat, no fan. Fuse is fine.
check see if power going to blower motor using 12 volt tesl light.if yes, remove blower motor, hot wire it.if blower motor works problem in the control switch or short in blower motor wiring,if blower motor dont work when hot wired,blower motor is bad.
Feb 07, 2012 | 1991 Volvo 240
Got in my car GMC Acadia this morning and the heat would not work. Tried the air and it didn't work either. Any thoughts.
check the fuse for blower motor. if thats fine use a multimeter and check for voltage at the connection to the blower motor itself under the passenger side dash. if theres power there then replace the blower motor. if theres no power there then theres a relay out between the fuse box and the blower motor. the blower motor will look like a black circle with 3 screws holding it in and wires going into it. there should be a quick disconnect there where you can test for voltage. replacing the blower motor is as simple as removing the 3 screws and dropping it down. there is probably a big plastic kick panel covering it that has to come off first to see it but it should be under the glove compartment.
Nov 10, 2011 | Air Conditioning and Heat for GMC Acadia
My 1999 alero fan will not work.I have replaced the blower motor and checked fuses and still nothing.The heat and air are working fine just not blowing.
Its either a bad connection on the blower motor resistor or a faulty blower motor resistor.These are known for over heating.
Oct 23, 2011 | 1999 Oldsmobile Alero
'94 Cadillac DeVille Concourse. My winsdhield
Follow the wires from the blower motor back to the blower motor resistor, normally only a few inches away and held in by a 7 mm screw. Replace it
May 13, 2010 | 1998 Cadillac DeVille
Front heater will not blow air...heat trickles out... have smelled burning smell when put on high....rear heat works fine
It sounds like the blower motor has burned out. It probably ruined the blower motor resistor at the same time. I think the blower motor is right by the right (passenger side) hood hinge and the resistor is just under the motor.
Dec 14, 2009 | 2001 Ford Expedition
How do I install a blower motor on a 2004 buick lesabre 3.8 v6
well colse the blower motor is going bad the bearings are worn out and can not be fixed.Replace the blower motor and you will be fine.
Aug 04, 2009 | 2004 Buick LeSabre
Front a/c heater blower wont work
Here is the order of checking;
) Check maxifuse 105
) Check fuse 24 on interior panel
) Check blower resistor
) Check power and ground at motor.
) May be bad motor
May 18, 2009 | 2001 Ford Expedition
02' LIBERTY BLOWER MOTOTR COMES ON WHEN IT WANTS TO.
Sound like a weak blower motor to me
Dec 12, 2008 | Jeep 10 x 20
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
