Question about Solis Master 5000 Espresso Machine
WHAT Is the process for using cleancaf on my solis 5000?
  • 4 Answers
There is an automatic cleaning routine for which I recommend reading the manual. The manual is not perfectly clear on this issue, and so I often go manual: Dissolve one packet in full water basket, use steamer to dispense ~1/3 of solution, let sit for ~10min, repeat two more times. Rinse well with fresh water!
Posted on Sep 13, 2010
I have a solis 5000 and the temperature of my coffe is to low . How can i get o hot coffe ?
Descale it!! any water (even RO) will build up scale. Once a month is good and I use 4x filtered water
Oct 17, 2011 | Solis Master 5000 Espresso Machine
Solis Master 5000 won't warm up
Hi
Sometimes when you first turn the machines on you need to run water through the wand to get them to start heating. If you have run water through the wand and it still won't heat up, you could have a bad board or sensor wire off, boiler wire off, bad element or thermostat.
Oct 19, 2009 | Solis Master 5000 Espresso Machine
Need a new heater tank where can I get one and aprox. how much are they? for Solis 5000
The only place I know of for Solis parts now is Empire fulfilment. Sorry I do not know how much it will cast for the part.
Oct 05, 2009 | Solis Master 5000 Espresso Machine
Grinder not working on my solis master 5000
Order the replacement boiler, (be sure to empty all of the hot water from the boiler first using the hot water function on the right side of your Solis) take your time and open the machine up, the top comes off. There are 3 mounting screws that hold the boiler in place, remove them, be sure to take hold of the boiler before removing the last mounting screw. Remove and replace the wires and 2 water hoses (w/clips). The orange wires the connect to a unique plastic harness are clipped into the harness. Look closely and you'll see a little window in the plastic harness at the end of each orange wire. Use a tooth pick or a pointed device and push the metal clips thru these windows, this unlocks the wires for removal from the boiler.
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=937
Good luck and Best wishes
Lane
Dec 19, 2008 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine - Need Repair
If you can remove the grind hopper(two screws) you can re-index the grinder for a finer grind.
Apr 21, 2007 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine Logo
56 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
