Sometimes the fan runs loud. Do I need to replace it?
    Scholar:
  • 128 Answers
Your fan runs loud can means that your motherboard's temperature is high and needs to be cool down. So your fun will kick in to high gear enable for it to do so.
Posted on Sep 09, 2010
My radiator fans running loud when I turn on my heat in the cab.
Check fan for debri, maybe you caught a cat.
also check fan blades for damage or loose.
Check the attached links, they address your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
New F150 ecoboost engine fans stuck on high F150online Forums
Fan loud in 5 0 Ford F150 Forum Community of Ford Truck Fans
Loud Fan Sounds Like Revving Ford F150 Forum
F150 Factory Fans running
Mar 08, 2016 | 2011 Ford F-150
Why does my fan on my Gateway ZX4931 always run loud?
does it has variable speed feature?, clean the heat dissipator, is clogged with lint and hairs! and always runs @ full speed, also if you're already there, might as well reapply thermal grease to the thermal dissipator.
ALSO, because you will have the fan dismounted, is so cheap you can put a NEW QUALITY fan (or fan dissipator combo) sometimes bearings gets loose and the axle wobbles (because of costs all OEM fans runs on cheap bushings) new aftermarket PRO-fans runs on ball bearings.
did you checked if a loose wire is not touching the fan blades?
Aug 06, 2014 | Gateway Computers & Internet
Loud fan sanyo xm150
You may need to replace the cooling fan. Sometimes the fan will turn but not as fast as it should, causing over heat on the unit.
Oct 09, 2012 | Sanyo PLC-XM150L LCD Projector
The dishwasher makes a horribly loud sound when running. I think it has to do with the lower "spinner arm". When I push it manually, it wobbles and makes noise. So I am guessing that spinning at higher...
It's noisy If your dishwasher seems noisy, check these: Water-inlet valve Motor Heater fan Pump Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve. Motor If it's the motor that's noisy, either of these may be the "culprit:" As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later). If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor. Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it. Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Nov 19, 2009 | Whirlpool Dishwashers
Dishwasher making loud noise during wash cycle
Water-inlet valve
Motor
Heater fan
Pump
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
thanks and accept the solution accordingly
Apr 03, 2009 | Kenmore Dishwashers
The fan in my tower sometimes runs loudly and for a long time
May need to be cleaned if that doesnt work
Replace the fan it sounds like its getting old
Mar 12, 2009 | HP Compaq dx2200 PC Desktop
Loud noise at end of Draining
1. Water-inlet valve
2. Motor
3 Heater fan
4. Pump
Water-inlet valve
Motor
Heater fan
Pump
good luck
thanks for using FixYa
Jan 28, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
My hp pavillion dv6000 laptop..the fan is unusually noisy??
Sometimes on my laptop the fan gets louder when it has been turned on when it is really cold or a hot environment. After I let it run for a while and then reboot it will operate as normal. I'm sure this is the same on a desktop.
If this is not the case then you would most likely need a replacement fan, as they do go out from use. In fact I've got a loud fan on one of my Desktops I will replace when I purchase a replacement.
Sep 17, 2008 | Computers & Internet
Samsung HLN507WX 50 rear projection
do you hear if the color wheel has been whining loudly?
clean the fans from dust.
Jan 20, 2008 | Samsung HLN5065W 50" Rear Projection...
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
