Question about Cycling
Rear axle diagram for schwinn beach cruiser - Cycling
  • 1788 Answers
SOURCE: I have an old schwinn varsity. I went to change
you need a new axle kit, and a cog removal tool. They used to be a Huret dearailleur if I remember right. I know a varsity never had Shimano. I think you may be better off buying a new rear wheel (it is usually less money than having to rebuild the axle) and let the bike shop do the change over, it is well worth it. You wont have to deal with the brakes,check the cones etc. Why did you have the Meridian adult trike on, and you have an old 10 speed Varsity? Kind of confusing.
Posted on Sep 18, 2010
SOURCE: need diagram on assembly of rear hub on huffy
need rear hub diagram for huffy beach cruiser
Posted on Sep 27, 2010
  • 1788 Answers
SOURCE: How do I remove the kick stand from the frame of
There is a special tool to remove it, but more than likely you have to find a dealer who has been in business for more than 20 years to have that tool. I would call the bike shops in the area to see if they have it.
Posted on Oct 06, 2010
dunnbiker
  • 8546 Answers
SOURCE: Putting the chain on the rear axle of a Schwinn
http://www.schwinnbikes.com/media/uploads/blog/files/Schwinn-Meridian-Manual_Mar2011.pdf
Page 12
Posted on Apr 27, 2011
dunnbiker
  • 8546 Answers
SOURCE: replacing a rear axle on schwinn bike. not a free
Maybe the manual would help...
How many ball bearings are there supposed to be on each side of the front axle of the Schwinn Point Beach model S4852WM bike?
There will always be a small gap in the bearing ring, and not all hubs take the same amount. However, if the balls are 3/16" there are almost always 10 on each side. If they are 1/4 inch (less common) then 9 is the correct amount. DO NOT replace only some of them - replace only in a full set of 20 or 18.
Sep 10, 2016 | Schwinn Cycling
How do I change the inner tube on my rear tire
This is no easy task!
You will need to remove the rear wheel to access the wheel, tire, and inner tube
Unless you have a single speed rear axle, you will be needing to disconnect the multi-speed gearing, which you may not really enjoy.
God bless your efforts.
Apr 19, 2016 | Schwinn 24in Riverside Girls Cruiser Bike...
When Coasting chain rolls backwards and falls off
Chains usually fall off because the chain is not tight enough. With the bike sitting upside down on the seat and handle bars the nuts on the rear axle should be loosened and the axle moved rearward so the chain tightens. When it is tight the nuts can be tightened. In addition to having a tight chain the rear axle nuts adjust the alignment of the wheel to the frame. You know you have it right if both the chain is tight and the tire closest to the crank is centered in the frame. The nuts should be tight enough so they don't allow the axle to move when you ride it. I hope this helps.
Aug 16, 2011 | Schwinn Windwood 26 Men s Cruiser Bicycle
My old Schwinn 26" red
Web search "fix shimano internal gear hub" or whatever the bike has.
Aug 09, 2011 | Cyclone Bicycle Pedal Crankset And Arms...
Schwinnn men's 26 " jaguar
The tires will say on the side-wall, it's likely around 45-50psi.
May 05, 2011 | Schwinn Men's 26" Jaguar Cruiser Bike
I have this Meridian Trike (Walmart purchase). I need a FREE WHEEL 16T SPROCKET to fit the rear axle shaft. the shaft is larger than 15mm & 5/8in ?? My local Bike shop could not help me with this odd...
Why not call a Schwinn dealer and ask if they can order it for you? You do realize that you void any warranty by altering you bike, don't you? But, if you don't care, look on the www.schwinn.com website and find a Schwinn dealer near you.
Jan 12, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
SCHWINN AIR DRIVER 1100:HOW DO I USE IT TO PUMP AIR INTO BEACH CRUISER TIRES
SCHWINN AIR DRIVER 1100How do you assemble the air pump for bike tire
May 09, 2010 | Cycling
Cycling Logo
442 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
