Question about Sony Walkman NWZ-B135 MP3 Player
Error boot. Do not start - Sony Walkman NWZ-B135 MP3 Player
  • 10,594 Answers
I disagree with this expert on this answer.
MP3 player needs firmware update and I can provide info for that if you still need any help.
Posted on Sep 10, 2010
  • 1 more comment
  • miss_lapoon Nov 04, 2010
    can you explain how you do that please. My one just has the Sony logo and nothing happens even when i plug it in
  • Shahid Electronics
    Shahid Electronics Nov 04, 2010
    I can help you to fix it, please post fresh question along with model number written on Sony mp3 player. Model number is very important info.
  • andy fraser Apr 24, 2013
    still available for help? I have a nwz-s545 .Reset makes no difference computer will not recognize and shuts down after boot screen.
    President:
  • 2,777 Answers
Sounds like the unit is having hardware problems. You will need to contact Sony for repair / support: 239-768-7547
Posted on Sep 09, 2010
Imedia system32 error
okay this is a confusing post/question. you can always start a machine from bio regardless of what operating system you're running. if you're attempting to boot from the disc, tap f12 @ boot until you get a one time boot menu and choose the dvd/cd drive. that should load the setup file. the windows disc does not load setup onto the hard drive. if you're running xp when you have the option hit 'r' to repair the computer, when you get into command prompt type sfc /scannow. this will search and fix all system files. you can also try chkdsk c: /r this will fix any errors in the file structure. good luck
Jan 30, 2012 | Packard Bell iMedia Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
On screen message telling me windows could not start because the following file is missing or corrupt- &lt;windows root&gt;\system32\hal.dll. Laptop does not start or boot properly
Time to get out that restore disc you made when you first got your laptop. The boot sector has errors. Boot with your rescue disc and run CHKDSK/F to clear the errors.
Hope that helps.
Feb 16, 2011 | ASUS Eee PC 701SD 8G Notebook
My laptop start but it doesnot reach windw after that black screen
It sounds as if you have a boot error in your start up sequence. Maybe caused by a hard drive error or corrupt file.
When the system is booting up press function key F8
Hope fully it will give you the option from there to load in safe mode. If it does, windows can repair itself. If not, you may need a boot disk to start up your system and then attempt to repair the errors.
Hope this helps.
Nov 17, 2010 | HP Compaq Business nx7010 Notebook
Non system disk or disk error
make shure in the setup it is set to boot off the mulitbay setting.. that is exacally what the evo says....
Jan 26, 2010 | Compaq Evo N610C Notebook
LG laptp booting problum
try starting your laptop in safe mode by pressing f8 during the boot up process
Aug 19, 2009 | Computers & Internet
ERROR LAODING OPERATING system
Please boot in safe mode and uninstall the driver.
To boot inn safe mode:
- Start your computer
- Press F8 ( Just before it start booting into windows)
- Select safe mode
Apr 19, 2009 | Microsoft Windows XP Professional
IE Error can't get past error, start screen and icons won't open
Dear,
To install the OS
1. Take a bootable disk of OS (XP).
2. Boot your system from cd rom.
Now installation process will direct you to take the steps.
Beleive it is very easy, try it
Regards,
Rakesh Kumar
Apr 11, 2009 | Acer Aspire 3000 Notebook
Boot Error please format unit
my rca mp3 player started saying boot error please format unit how do i fix this so i can hear my music again
Mar 19, 2008 | RCA OPAL M4001 MP3 Player
Booting up to windows or cdrom
please try to boot with window server 2003 Cd .If that boot from server then error is with the OS which you installed
Dec 26, 2007 | AOpen AK77-600n Motherboard
Sony Walkman NWZ-B135  MP3 Player Logo
302 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
