Question about Woods 247 cu. ft. Upright Freezer FU25
I have a 2-door freezer - F2027DW4 20CF VERTICAL. Ice and frost is building up at the front of the top door. What causes this and how do I fix it?
  • hhughes956 Sep 09, 2010
    Thank you for your reply. It does not help me solve or fix the problem and therefore I request the $6.00 charge be reversed.
    Genius:
  • 1,478 Answers
Check the defrost timer, defrost heater and defrost thermostat. There could be a problem with any of these components, they are most likely cause of the problem.
A mechanical defrost timer controls the defrost cycle of the freezer. In older models, the timer runs continuously and roughly every six hours, cuts power to the cooling system and sends power to the defrost heater. In newer models the timer advances only while the compressor or defrost cycle is running - an improvement for efficiency. As the timer continues to advance, power to the heating element is cut and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Posted on Sep 09, 2010
  • 503 Answers
The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Why is the top of freezer frosting up
The door gasket is leaking around the top of the door. Air getting in past the gasket condenses in the freezer causing the ice build-up.
Sep 07, 2014 | Freezers
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Hi My beko frost free freezer has been building up ice in the little grid thing at the top of the freezer. The temperature was also driopping ( to 8) and so I have put it on fast freeze to raise temp. What...
check the door seal on the top of the door if not sitting flat to the frame it will encourage frost to build up (inside the little grid thing)which will stop the rest of the freezer from cooling enough.
Jun 14, 2010 | Freezers
Upright freezer,automatic defrost. problem: ice build-up in the bottom.
get down on the floor and look along the bottom of the door to make sure that the door seals are touching.if not and you have an air leak it will cause frost.if its ice and not frost then check all vents/drains are clear.
Mar 17, 2010 | Freezers
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Alot of ice builds up at the top part of the freezer; a small black w/ stainless looking front. Friend thinks it is moisture air is leaking in through door seal.
yes. if the door seal is not making good seal then when the unit is running it will **** air in from where the seal is failing and create frost build up. need to inspect seal and make sure its making good contact.
Jun 25, 2009 | Freezers
Kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Jun 20, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Jan 14, 2009 | Frigidaire 13.7 cu. ft. Upright Freezer...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Woods 247 cu. ft. Upright Freezer FU25 Logo
170 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Mike Squire
Are you a Woods Freezer Expert? Answer questions, earn points and help others
