Question about HP Photosmart C6180 All-In-One InkJet Printer
I cannot turn the printer on. I get a message that tells me I improperly turned the printer offf without using the Off/On switch and damaged the machine
  • HP Master
  • 6,487 Answers
To fix the issue , hold down the # and 3 keys at the same time then unplug the power to the printer. Hold the two buttons down while leaving the printer unplugged for 30 seconds then plug back in the printer while still holding down the buttons. Keep the buttons held for 15 more seconds then release, the error message will come up again as the printer cycles but, just press ok and it will go away and stay away.
Posted on Sep 09, 2010
Hello. i have the hp Photosmart C6150 printer. for
Press the button on the printer, to turn the printer off.
Then, press the switch on the power-bar, to completely cut the power to the printer.
Turn the power-bar on.
Turn the printer on.
Jul 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error Message is "Improper Shutdown" It says something like "To avoid damage, use the On button to shut down the device. Do not use the power strip or wall plug to turn off device. Can't get the machine to...
Reset the printer by following steps
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Apr 10, 2010 | HP Photosmart C6100 All-In-One Printer
"Improper Shutdown" - Printer keeps turning on and off.
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
8. Be patient to let printer run its tests.
Sep 12, 2009 | HP Photosmart C6100 All-In-One Printer
Printer cycles on/off and displays "improper shut down"
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Printer will not start
This is likely a hardware problem. However you can try a sem-full reset to factory default conditions by 1. unplugging the power cord while the printer is powered on and 2. press and hold the OK and Cancel buttons while plugging in the power cord. If this this does not clear the error you probably have a hardware issue. On my printer, after going through a diagnostic procedure with the HP Chat Tech and concluding a hardware issue I did a bit more research and then took the printer apart. It turns out that a fairly common problem is for the large white gear on the left side of the printer that drives the ink pump comes off the shaft. I reassembled it to the shaft and put the printer back together. When I plugged in the power cord the printer started and did about a 5 minute maintenance procedure and now works fine.
Nov 24, 2008 | HP Photosmart 3210 Printer
When I turn on my printer I get the message Error Press OK
You have to refit the micropump gear, this is happening because this gear should be out of its place. It's on the left side of your printer. I.ve just solved the same problem.
I have a canon 400d eos digital camara, and when i try to use an error message is displayed error 05 the built in flashes auto pop up was obstructed i have attempted to turn off and on without success...
There is a little switch that tells the camera if the flash is up or down. if your flash is up and you get this message then the switch is eather damaged, a tab is broke or the mainboard is acting up. Thing are a pain let me know if I can help you any further. Hope this helps
Jul 03, 2008 | Canon Cameras
Machine shuts off immediately
your ac driver could be damage or a connector is loose
Jun 18, 2008 | Canon imageRUNNER C3220 Color Copier
HP Photosmart C6180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
