Switch section in mother board burned - Computers & Internet
  • 11,800 Answers
This cannot be fixed, you need a new motherboard. For a laptop it will be expensive.
Posted on Sep 09, 2010
Hotpoint fridge clicks before starting
You have a possible compressor relay going bad or something like low house power could cause that. Also the mother board could be going bad without seeing any problem. Electronic boards sometimes go bad without being able to actually see it. The compressor part of the board will sometimes burn a spot on the mother board but can only be see on the back solder side.
Apr 07, 2015 | Hotpoint Refrigerators
MX 351U SHOWING E7-90 ERROR CODE WHAT THE SOLUTION
This is a PCU PCB Communication error. 9 times out of ten it will reset by simply switching the machine off and then on again. If the problem persists here is the section from the manual that describes the possible causes and remedies.
E7-90
MFP - PCU PWB communication error
Trouble content
Detail
MFP
Cause
PCU PWB connector connection trouble. PCU PWB - MFP PWB connection trouble. PCU PWB trouble.
MFP PWB trouble.
Mother board trouble.
Check & Remedy
Check connection of the PCU PWB, the MFP PWB, and the mother board.
Check the ground.
Replace the PCU PWB.
Replace the MFP PWB. Replace the mother board.
I hope this helps
Good Luck
Follow me on Twitter @CDOS_Service
Jan 14, 2014 | Sharp Office Equipment & Supplies
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
Display window has a light but no information
Possible failure of the mother board/ power supply section. You will need to remove and reconnect the lines from the mother board to the display and sections.
If there is no result even after this with the display staying blank then the board can be faulty.
Nov 19, 2010 | HP LaserJet 2420 Printer
My s88m g/gl motherboard is not switching on ,but the power supply is working
Power supply is other thing, means she ( Power Supply ) supply the power to *********** board. When mother get the power than she supply all the device. If, *********** board have problem, means not connect properly or burn ( any device ) than she not run. Better you check your all connect device with processor also.
Aug 12, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Refrigerator section does not cool. Light or LED behind refrigerator control knob does not light so you can not see the current setting. Freezer section works fine as does the freezer control knob light.
these refrigerators are notorious for a bad main/mother-board being bad,especially if recently you had light bulbs have burned out in the refrigerator compartment as this creates a surge on this board and burn the printed circuit trace on the board,it is located in the lower rear of the unit and is housed in a plastic case and if you open the case and look at the board and case there will be a burn spot on the plastic case also
Mar 13, 2010 | GE GTS22WCP Top Freezer Refrigerator
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
