Question about Mantis Tiller
I CAN'T GET FUEL TO THE PRIMER BULB. THIS IS THE SECOND BULB I'VE INSTALLED, BUT THIS TILLER HAS BEEN IN STORAGE FOR OVER A YEAR NOW. SHOULD I REPLACE THE BULB AGAIN?
  • 183 Answers
The problem is probably not the bulb itself, rather the fuel orifices within the carburetor are clogged with old gummy fuel. Sometimes, just draining the old fuel and adding fresh fuel (properly mixed) to the tank and let it sit a few days, will allow you to pump the fresh fuel through the carb. If this doesn't work, the carb will need to be removed and cleaned. I also strongly recommend to replace the gaskets and diaphragms within the carb when it is cleaned. As fuel ages, it gets thick and eventually turns to varnish. In the future, make sure that you run all of the fuel out of the equipment, or use a fuel stabilizer. Stabilizer will usually keep fuel good for 6 to 8 months instead of the 60 - 90 days without it.
Posted on Sep 09, 2010
Just bought a carb kit. Which way does the diaphragm go in ? Also,the primer bulb won't show gas.
if the primer bulb cannot pick up fuel and the fuel lines are good then you have a bad primer plate and you need a new carb
Mar 25, 2015 | Mantis 2-Cycle Tiller
Vapor lock on Mantis
check the fuel lines for a breakage or the primer bulb for a crack. Sounds like it is sucking air instead of fuel
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 06, 2013 | Mantis 2-Cycle Tiller
PRIMER BULB ON TROY BILT 144 TILLER WILL NOT FILL
look for a cracked fuel line or a split in the primer bulb
May 17, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
Hello, my Ryobi 410r tiller/cultivator needed new fuel line so I bought the fuel line, return and a new bulb primer. Unfortunately, I can't remember what hose goes where!!! Specifically, I've...
The primer pulls fuel through the carbruetor
So take your return line from the carb. and hook it to the inlet side of the primer and the other side
of the primer bulb transtions into the fuel tank.
You know when you have hooked it up right when you press the primer it fills with fuel and dumps back into the tank.
Jun 16, 2011 | Ryobi Garden
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
The primer does not fill up completely and gas does not flow into the tube. I have difficulty getting the edger to start
Check that the primer bulb has no cracks in it.I would change the primer bulb you have air getting into the fuel system that is causing your fuel to run back.
Aug 08, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
Jun 08, 2009 | Mantis Tiller
Would like to know what year this tiller would be.
replace primer bulb. If that's not the problem check the float in the carb for pin holes . check fuel lines and intake line
May 15, 2009 | Mantis Tiller
Mantis Tiller Logo
168 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
