Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
My ceiling fan is spinning in the WRONG direction. I know because I have an identical fan spinning in the right direction. How do I get my fan to spin in the right direction? It has been doing this ever since I moved in last week.
  • 3,640 Answers
Shut it off, an get up there and see if it has a directional switch, to make it go forward or back wards. also be sure the blades are not upside down on fan motor. the reverse switch should be on the fan motor housing so it can be reversed.
Posted on Sep 09, 2010
Testimonial: "I reversed it back. I wonder why it has 2 directions."
Fan is spinning opposite way
there should be like a switch to change direction of fan , if not then you need to change the wire connection , try that , AJ
Aug 13, 2009 | Ellington ROC52ALUM3LKRCR2 Rocket Ceiling...
New Hampton Bay ceiling fans spin too slow
Slow spinning of the fan might be caused by a low voltage. Is there any way you can measure the voltage, and if the wires are properly connected, check for any loose wiring or rust in between connections. Maybe the breaker that supplies power to the fans has a loose connections inside, try putting a new breaker of same rated current. Check if those three fans are connected to the same breaker. Breaker can go bad from the inside not doing a proper connection and supplying a low voltage, this might be causing the slow spinning of the fan. Second the black box in the space with all the wires is called the capacitor.
May 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Apr 28, 2009 | Emerson CF2600PW Raphael Pewter Ceiling...
Fan is spinning the wrong way
Have you checked to see if there is a switch on the fan housing? Usually this is how you select the direction the fan is spinning. If it's spinning clockwise as you look up at it, it's blowing air up. If it's spinning counter-clockwise it's blowing air down.
The remote not working could be:
- it needs resetting/synchronizing with the receiver, or
- the battery (ies) is dead, or
- the remote (transmitter) or the receiver is bad, or
- the receiver has loose connections.
Check the owner's manual -- do you have one?
Apr 22, 2009 | Ellington ROC52ALUM3LKRCR2 Rocket Ceiling...
I have found the right solution to the fan not working in the right direction. the problem is that is a pcs of trash, i ripped mine off the ceiling and tossed it out the window and guess what it, it flew...
Did you hit the reverse direction switch located on the upper fan body. Upward direction is for winter as it blows up toward the ceiling pushing rising heat out towards walls and down to floor. Downward direction sucks heat off ceiling (summer months) and pushes cooler air that is on the ground toward the ceiling, thus giving a cooler airflow. You do know that there is a little black switch up there, right?
Feb 28, 2009 | Hampton Bay 24002 Ceiling Fan
Cannot change the direction of my fan...
Your reversing button for that particular model is on the remote control. There is no button on the fan body itself.
Jan 03, 2009 | Hunter (25417) Ceiling Fan
NO Reverse switch
That's because they only go one direction.
Aug 24, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
505 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
