Question about Polaroid i532 Digital Camera
How do you unlock card locked - Polaroid i532 Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 09, 2010
Sim card not supported
If the Sim card Not support means it may locked to network.You need to unlock it...You can get the network unlock code from the site Onlinegsmunlock.com/samsung/rs7wp8/ for SAMSUNG GSM Network locked Phones and unlock it from Network lock.You need to specify the Model?
ALSO check whether it not support only one Sim card,if that problem means it may CDMA Network,OR may Sim card problem.If it not support other Sim card and support only one Sim means it's Under Network lock,You need to find the network,country it locked now and unlock it using the Unlock code,Only GSM Network lock Phones can be unlocked,CDMA network locked Phones cannot be Unlocked from the Mobile Phone.
Dec 06, 2011 | Samsung SGH Cell Phones
Sim card error
What is your Phone Brand and it's Model?
Make sure that your phone has been unlocked....If the Phone Locked means if you insert Other Network Sim card means it says invalid Sim or Sim card error...So find out the Network and country locked now,all network locked Phones cannot be unlocked ,Some Network locked Phones can be Unlocked.It depend on the brand of the Mobile also,you can unlock it using the Unlock code,You can get the Unlock code from the Theunlockarena.com
and Unlock it,after Unlocked the Phone use any GSM Network Sim card,You cannot use the CDMA Network Sim Card in the Unlocked Phone,Only GSM Network locked Phones can be Unlocked...
Jul 04, 2011 | Cell Phones
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
How do you unlock camera card it says card locked
Hi. Remove the card. On the side of the card is a small sliding lock. That's it. J.
Jul 12, 2010 | HP Cameras
Unlock memory card
There is a little 'lock' switch on the side on the card with a lock symbol. Slide the switch to the unlocked position to unlock your card!
Aug 06, 2008 | Cell Phones
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Cameras Logo
35 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
