Question about GE Dishwashers
There are small black spots on the dishes when the cycle is complete. The spots can be rubbed off, and are not hard or granular. The black material is flat and roundish, but when rolled between thumb and finger it becomes elongated and will leave a black smudge if pressed against a sheet of paper.
  • 101 Answers
Internal rubber gaskets deterating
Posted on Sep 10, 2010
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
Dishes come out of dishwasher with a sticky film, and after the dishes cool off the film hardens and is almost impossible to remove.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 22, 2011 | GE Profile PDW1860NSS Builtin Dishwasher
THERE IS A FILM ON THE DISHES AND RACKS AFTER THE CYCLE HAS COMPLETED.
Hi
Daniel
Feb 13, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Right after 1 year, now there is a white film on all the glasses and bad spots, that rubs off if you wipe it fresh out of the dishwasher. Yes, we are using rinse aid.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Dec 04, 2010 | Whirlpool 24" Black BuiltIn Dishwasher...
My dishwasher is putting little black spots on my clean dishes, hard to get off
aluminum untensils have rubbed against the dishes,use a mild abbrassive cleaner to eliminate marks....... how do i let inlet water out of my candy dishwasher
Mar 30, 2010 | GE Dishwashers
The dishes in the top end up covered in baked on residue after cycle completed. They are dirtier after washing than before. As if bits from below are splashing up during the cycle and not being rinsed off.
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 13, 2010 | Beko 24 in. D3421F Free-standing...
Glassware is cloudy
Nov 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes havin milky film
Nov 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Microscreens on Maytag Dishwasher
where to find the sand filter on a maytag dishwasher?
Nov 01, 2007 | Dishwashers
Dishwashers Logo
370 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
