Question about Dell 3100cn Laser Printer
Printer Keeps saying processing Port 9100 and will not print
5 Suggested Answers
  • 88 Answers
SOURCE: Printer keeps processing - nothing happens - no print
Not really sure about Mac, but if this happens on a PC, I would first uninstall the printer (software-wise) then download the latest drivers and install.
Posted on May 27, 2009
SOURCE: Laserjet 2420d just keeps printing document repeatedly from XP
check hp for latest driver for your operating system, also check if there is a PCL and PS driver. PS is better for PDF. sometimes an adobe update can cause these issues so if you cannot find a driver update you could roll back adobe to see if that fixes your issue.
Posted on Aug 07, 2009
jayatithapa
  • 83 Answers
SOURCE: Green button keeps blinking and it says processing
Change yours data cable clean yours printer port and system port
Posted on Mar 16, 2011
  • 1570 Answers
SOURCE: The printer green light keeps
Hi
Try this solution
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Posted on Apr 14, 2011
Canon laser lbp3300 incorrect port error
change tcp port to 9100
in port settings in printer properties
check firewalls allow access to port 9100
Dec 04, 2013 | Canon LASER SHOT LBP 3300 Printer
Xerox Phaser 6125 stuck on Processing LPR
Try this:
Go to Ports in your driver properties
Go to configure port
Change your protocol from LPR to RAW
and check if port is PORT 9100
May 08, 2013 | Xerox Phaser 6125 Laser Printer
How do I find the new IP address for the Zonet ZSP3611 Printer Server so I can set up my printer to work
An easy way would be to download and install nmap. For the IP address to scan, if your computer ip is say, 192.168.0.52 then enter 192.168.0.0/24 and select the quick scan. Whichever device comes back with an open port of 9100 is most likely the print server.
May 08, 2012 | Zonet ZPS3611 Print Server
Aug 07, 2009 | HP LaserJet 2420 Printer
Laptop keeps trying to install imaginary printer at startup.
I'd completely uninstall them if they are not going to be connected to the system, but leaving them disabled shouldn't hurt anything either.
Mar 26, 2009 | Toshiba Tecra 9100 Notebook
HP2840 color printer
I opened UDP port 9100 through my firewall and my documents now print.
Aug 22, 2008 | HP LaserJet 2840 Printer
Emulex NetJet Print Server Problem
The standard port settings used when setting up a Printer Port is Port 9100 (TCP) when normally communicating with the Jet direct / LaserJet 4 plus printer.
However when using the Emulex Card it s default is Port 2501 (UDP). So within XP change the Port setting to 2501 and it then will communicate correctly.
Aug 17, 2008 | Emulex NetJet (NJ01B-NTplus) Print Server
PagePro 9100 says "1 active job" but won't print
I found out that it was some (vector) snowflakes we had in the art that had gradients that caused the printer to freeze.
We removed (in Adobe Illustrator® CS3) all of art work then replacing it on piece at a time, printing OK until we added the snowflakes. Turning the gradients into just halftones was our solution. The printer representative is going to give our printer a memory upgrade for free.
Feb 20, 2008 | Minolta QMS PagePro 9100 Laser Printer
Network printing
If you can see it, it is set up right, however, the configuration might be wrong. Go to printer properties in the control panel. Open up the ports tab, select configure port. You will see that it is probably set: protocol:Raw, port:9100. Sometimes the port is 10001. Otherwise, set it to LPR, and put LP1 for the queue Name. That should do it.
Feb 20, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Dell 3100cn Laser Printer Logo
1,195 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
