Question about Maytag CWE5800A Electric Double Oven
Maytag oven, top door has lost the middle open position, falls freely and does not close well on its own. Model cwe5800ace. How do I access to inspect and/or repair?
  • 944 Answers
Here is the body parts diagram of the Maytag CWE5800.So this will help you out in more depth.Please the link to so you can see other parts how it is linked to door too.
Click here to get to the body parts diagram.how to assemble it.
Hope this will help you,
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 09, 2010
The oven door will not close .
i just had a similar problem .the door would fall and i had to lift the top of my door hinge to close it .I found that the pin on the door hinge spring had fall.en out . I installed it back and now it works the way it should.the spring should feel tight with no movement.
Mar 25, 2014 | Dacor MCS130 Millennia Electric Single...
We've got a broken door spring on our Maytag CWE5800ACE Oven. We pulled off the top door and disassembled it when we realized the springs are inside the oven unit. OK....Can anybody can offer some...
My father-in-Law has the same issue and I found the spring as part of the hinge assembly. The link is "http://www.appliancepartspros.com/part_details.aspx?part_id=4092260&image=1" and the part number is Part Number: AP4092260
Made by WHIRLPOOL. Hope this helps!
Dec 01, 2010 | Maytag CWE4800A Electric Single Oven
Oven door falls open and will not close tight on my Jenn-air Single oven Model #SVE47100w
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
Jul 24, 2010 | Jenn-Air Electric Single Oven
We purchased our oven used, so we don't know much about it. We think, by looking at pictures, that it is a Maytag CWE5800ACE however, we can not find the model number on the oven. We know where it is...
Here is a web site for most of the parts for your unit:
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=459294&ST=PBM
They also have a phone number, so you may want to call them for additional information for your specific appliance.
As always, if you get stuck, please post another message at FixYa for more help!
Jan 13, 2010 | Maytag CWE5800A Electric Double Oven
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
Have a maytag super capacity plus oven i tried cleaning the oven now the door will not open and it shows f9 on the front
Had the same problem. How I fixed it, was by using a very thin, and I mean really thin, flat tip screw driver and a flash light. Unplug the stove. Use the flash light to look at the very top of the oven door. You should see in the air vent slats a silver hook. Use the screw driver to go through the vent slats and push the lock open. Now, you should be able to open your door. But we arent done yet. With the door open, plug the stove back in. Close the door and wait for the F9 to flash. Now open your door, and on the right side you should see a tiny peg sticking out on the open oven. Its for the light to come on when the oven door is open and also to let the oven know the door is ajar. Push it in and wait. The door latch circuit should reset like normal, and you will see the latch move back into its normal open position. Which resets the F9 error and allows you once again to use your oven like normal.
Dec 20, 2009 | Maytag Ovens
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do get access to the door hinge of my Maytag CWE4800ACB oven
In first, excuse my poor english if i make some mistake.
I hare repair the same problem. part broken in left side and the door fall.
You have to pull out the oven from the wall, use some objet to support the oven,small table or plastic box if you dont want to put down completely.
You have to unsecure the electric wire connection in back if you whant to pull out enough for remove the left cover. You have to remove some parts in front for acces to screws on the side cabinet.
In my case the hinge was broken, i have soldered and fix again.
If hard to replace the spring in the mecanism, you better to do this on the bench before put all in the side of the oven.
I think the maytag oven have the same problem.
Other problem also is the timer alarm sound in the night went you sleeping, prob whit switch sensitif pc board. Now i turn off the breaker in the back of oven all night, and i sleep good.
Bye..
Mar 24, 2009 | Maytag CWE4800A Electric Single Oven
My oven door no longer closes properly it falls back open
Hi
you dont say what make or model it is, but from what you do say sounds like the door hinges have failed just replace and should be back to normall.
regards dan
Mar 19, 2009 | Ovens
Maytag CWE5800A Electric Double Oven Logo
158 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
