Question about Datamax DMX-I-4208 Label Printer
Booting... ram test failed - Datamax DMX-I-4208 Label Printer
My desktop frequantaly booting what can i do
When you say frequently rebooting; Is it randomly rebooting without warning? Do you get a BSOD (Blue Screen of Death) error message? Or does the PC just reboot without any error's other than windows was not shutdown properly?
MOST random reboot issues are caused by Power issues;
-Failing Power Supply
-Blown Capacitors on the motherboard
-Insufficient power to run the system.
These would be a good place to start to troubleshoot if you do not get a Blue Screen Error Message.
-Failing Hard Drive can cause this issue as well but is usually acompanied by a Blue Screen Error of sorts.
-Failing RAM again usually accompanied by a Blue Screen Error.
You can test for failing hardware, by using Hiren's Boot Disk for diagnostic tests on your Hard Drive or Ram.
Hiren's Boot CD 15.2 - http://www.hirensbootcd.org/files/Hirens.BootCD.15.2.zip
You will want to run memtest X86 to test the Ram or Hitachi's Drive Fitness Test or SeaTools to test your hard drive.
This BootCD is not for the typical end user whom may not know there way around the features and options this Tech CD provides.
You will want to burn the Hirens Boot.ISO file to a CD (Burn Image Option) using any of your favorite flavors of burn software.
Hope this helps.
You can also download these diagnostic test individually such as memtest x86 and Hitachi's DFT or SeaTools independently from the Boot CD just by doing a google search. This might be the easier way to perform these tests for people who aren't very savvy with boot CD's.
Dec 09, 2013 | Intel D845GVSR Motherboard
N1996 motherboard 4 fast bios beeps
The beeps actually refer to memory not just RAM, it could be the memory on your graphics card or the cache ram on your processor. Or it could be a compatibility issue between memory sticks.
Sep 18, 2012 | MSI Computers & Internet
New memory, the board just beeps
First of all that board supports DDR400 (PC3200) so why did you get PC2100 chips?
Anyway, do a bare minimum test (only MB, CPU, RAM & PSU connected, nothing else). Remove all the RAM and test each one individually. Properly insert one into the first RAM slot and test by booting until the POST RAM test is finished. Shutdown and repeat the test with the same RAM module in slot 2 and keep repeating this for every slot. If successful in every slot, mark that module as working then try the other RAM modules using the same procedure.
  • As soon as you find one that doesn't fully pass the POST test, mark it as faulty.
  • If some pass in one slot but not another, then mark it as faulty.
  • If they all fail to pass on a specific slot, mark that slot as faulty and don't use it (you can use electrical tape to cover the slot for future reference).
Once you've finished the bare minimum test, try 2 RAM modules this time (use only the modules that you found to be working from the above tests). Mix and match the RAM modules & then try 3 together and even 4 (if you found all of them to be working fine).
Finally once you're satisfied you've found the modules that work properly, boot with memtest and test the RAM for any problems. If they all seem to work fine individually, boot them individually and test with memtest to determine which ones are actually faulty.
Jul 13, 2012 | HP Compaq Presario SR1610NX (ED865AA) PC...
Why is my Dell Optiplex 320 indicating orange led and not booting nor display?
check the ram.change the slot and disconnect the hardrive before that
Apr 19, 2012 | Dell Computers & Internet
Am asking if you try booting with out the ram and it still beeps 3 times does it mean that still its the ram problem.
if you try booting without ram and it still does the beeping, it is most likely the memory, best way is to try a memory test software that you can run off a cd. like memtest+
Apr 09, 2012 | HP Computers & Internet
Twice beep sound is coming. Booting is not happening for my p4p800 mx/s board
Hello !
If you check out ASUS support, you will find this troubleshooter for the motherboard not booting :
1. Please clear CMOS.
2. Please take out your memory cards and video card, try to clean their golden connectors with a rubber, then reseat them back.
3. Please take the CPU cooler out, add some thermal paste to the CPU surface, then reseat the cooler back and keep the cooler tightly installed.
4. Please keep the necessary components(CPU, one memory) onboard for a test.
Finally, we would recommend you to replace a BIOS battery to have a test.
Also, by looking over beep codes I have found for AMI BIOS these problems for the 2 short beeps :
1. Memory parity error (Description : A memory parity error has occured in the first 64 KB of RAM. The RAM IC is probably bad).
2. POST fail (Description : One of the hardware tests have failed).
If you have done those and it still doesn't boot, let me know I'll try to find other solutions.
All the best !
Aug 03, 2011 | ASUS P4P800-MX Motherboard
CONTINUOUS BEEP WHEN I BOOT UP MY PB IMAXD3413
Issues with Ram modules not inserted properly, or not suited to the board, but more likely a failing CPU fan which is not turning as the computer is booted, check fan connections and use a multimeter set to 12 volts to see if there is a feed coming from the two outer fan pins on the motherboard (or try a other fan)
Jul 27, 2011 | Packard Bell (181368) Motherboard
Windows failed to start. a recent hardware or software change might be the cause.
Uninstall Internet explorer 8 and any .net upgrade which is rescent. Try it now and use internet explorer 7 if it is working ok with downgradeor better goto firefox and download firefox.
Other possibility is RAM has failed, if there are two sticks try booting with one stick in theA slot and other removed, alternate the ram sticks to test. If only one ram stick try a similar ram type pc or laptop for ram test, a friend?
Jan 25, 2011 | Dell Inspiron Mini 10 Notebook
My laptop is not booting after switching it on only CD Drive light is blinking , but nothing is happening afterward. No display or booting from HDD, no bip from RAM. What can be the problem?
The most likely cause is the harddisk - it has failed. This is easy to test - just boot from a Linux Live-CD like
http://www2.mandriva.com/ro/downloads/
Nov 11, 2010 | Dell Inspiron 1501 Laptop
Windows cannot loaded at bootng time
check the RAM use it on different slot or use a different RAM
Oct 13, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Datamax DMX-I-4208 Label Printer Logo
83 people viewed this question
Top Datamax Office Equipment & Supplies Experts
pkwc
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
