Question about Hotpoint RLA80 Refrigerator
I have a hotpoint RLA80 the back wall on the top half of the fridge keeps freezing although the temp is on 1
  • yvonne12 Sep 12, 2010
    there is no freezer this is just a large fridge
  • Hotpoint Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
Hotpoint RLA80 Fridge. Huge buildup of ice at the top of the fridge as though not defrosting.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Hotpoint RLA80 Refrigerator
LG Larder Fridge model GR-252 SBD IS FREEZING ON INSIDE BACK PANEL A LUMP OF ICE FORMS. How can I stop it?
this is a defrost problem . either the A D C a pc board on the back side of the frig . this main board controls the temp[t and the defrost . and has failed . repl it and problem is over .. mm hope this has helped .. feed back pls ..
Jul 22, 2010 | Hotpoint RLA80 Refrigerator
Why does it freeze inside the fridge and the some of the contents are frozen, the therm temp is at 1
theres several reasons for that! #1 is that the vent's inside the box are not! closing all the way off with the temp controller set at #1 #2 is that most units with icemakers and other accessories tend to get full of ice which inturns allows the storage of ice in the tray/box to freeze!! the walls between the freezer and fridge side! due to poor insulation in the box it's self and a flaw in design. its like setting a empty pan on a block of ice then when you feel inside the pan after a while its cold as the outside where the ice is? follow me so far? i knows its a pain but the way these newer units are made there basically made to sell! there is 2 things you cna do! here #1 is put a new temp control in it and number 3 keep the ice tray half empty or more till you need ice
Jan 18, 2010 | Hotpoint RLA80 Refrigerator
Hotpoint RLA64 getting too cold.
The thermostat capillary on a Hotpoint RLA64 (and possibly RLA80) is inserted into a tube. The tube becomes detached from the cooling element and so does not sense that the fridge has reached the desired temperature. It then carries on cooling resulting in ice build-up and freezing of goods.
As you cannot remove the top or back of the fridge, you cannot fix the capillary tube back into position. What you can do however, AFTER ISOLATING THE FRIDGE FROM THE MAINS SUPPLY, is to drill a small hole adjacent to the thermostat capillary tube and another in the roof of the fridge next to the interior light and pass the thermostat capillary INTO the fridge cabinet. Use tape to attach the capillary across the roof of the fridge and down the centre of the rear wall curling the last 50mm or so back up towards the top of the fridge. As long as you have dried the wall of the fridge and stuck the capillary securely in place, your fridge should now work correctly when powered up.
Only tackle this job if you are confident and ALWAYS ISOLATE the mains supply.
Jul 03, 2009 | Refrigerators
Things freese-up in the kenmore fridge
Try turning down the unit a half knotch, 1 full knotch at MAX, the cold air comes from the freezer to the refrig(fresh food) section, its rolls up the back of the wall to circulate it
A fridge that is to cold is usually shown when food nearest the back wall freezes( i get this call plenty times a day, this is the fix)
recommened freezer temp 0-5, fresh food(refrig) temp is 32-40
May 02, 2008 | Amana AFD2535DES French Door Refrigerator
Ice of the back of refrigerator
probably the wrong thermostat fitted - the cut back temp varies and is important
Jul 08, 2007 | Hotpoint RLA80 Refrigerator
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint RLA80 Refrigerator Logo
296 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
