Question about Xerox 8830 Copier
It tells me I need to replace something. It is the circle one that is blinking
    New Friend:
  • 51 Answers
Ceck its toner cartiage
Posted on Dec 12, 2010
What is topcon pipe laser tp-l4 error code 03
ERROR 03 is a grade circle reading error. The grade system uses an etched glass circle, the same as a digital Theodolite or total station uses, to measure it's grade. If there is a problem with the readings of the circle then values have been lost telling the circuits how to read that exact circle properly, or something has become damaged. I've seen a number of them where the circle was intact, however no longer attached to the axis shaft it is supposed to be permanently fixed to.
The user manual says to turn the unit off and back on, to see if it was just a momentary glitch. I would also remove the battery and external power for a few minutes before I turned it back on. Unfortunately, if that doesn't solve the problem the signals are going to have to be realigned, and parts may have to be replaced. In order to realign the signals, a standalone power supply is needed, as well as a digital oscilloscope and Topcon tolling, called "illuminators".
Aug 28, 2014 | Topcon Tp-l4a Red Beam Pipe Sewer Laser W...
Free online auto repair manuals
I believe that is your brake pad warning light. Simply put it's a warning light that your brake pads are worn to the point that they should be replaced.
Hope it helps.
Mike K
May 10, 2014 | Mercedes-Benz 190-Class Cars & Trucks
Hi, I got a PSP 3000 and the circle button is pressing by itself, it seems something under it are stuck to the MotherBoard but im not sure what the real problem is. Now I can't play games because every...
Hello.
You need to open up your PSP (But it will void the warranty!) remove the circle button and then make sure there is no dirt under it, then replace it back. It is not that hard to open a PSP, you can find many videos on how to do it.
Aug 03, 2011 | Sony PlayStation Portable (PSP) Console
Pls help me: xerox workcentre 24 code: 116-372
Ugh.. That is a formatter software issue. Try these resets
arrwup.gif Log Initialization
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif Spool Initialization
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif HDD Initialization
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif ESS NVM Initialization caution.gif CAUTION
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
Mar 12, 2011 | Xerox WorkCentre M-24 Color Copier
On a 2001 Ford Taurus - what does the yellow or amber circle - it looks like a cog - with an exclamation point in the center mean when it is blinking?
its a check transmission light. You need to take it to a transmission shop and they can read the problem code and tell you whats wrong.
Mar 02, 2010 | 2001 Ford Taurus
Blinking green circle & burning odor
Check the powersupply the little black box in the middle of the power cord see if it smells ok if not then it has failed, just buy or find another powersupply with the same voltage and same or more amps than the other one and try it. if the smell is coming from the MY book itself then it's probly the Drive in whick case it needs to be replaced.
Feb 24, 2010 | Western Digital My Book Essential Edition...
Blinking circle with black dot - 400si
If its on the top panel, its telling you that there is a film cartridge in the camera, already rewound and ready to come out.
Dec 26, 2009 | Minolta Maxxum 400si 35mm SLR Camera
My timer knob on my Splendide 2100 keeps going round and round
This is a onboard diagnostic system. As soon as the knob starts going in circles start counting the red light blinks. Then call Splendide. Let them know what is happening. When they ask tell them the number of light blinks that occurred and they can tell you what the error code is.
Aug 12, 2009 | Splendide 2100 Vented Washer-Dryer
Its frozen at the screen with a square with circles inside! help!
Call T-mobile, they will send you a replacement phone via mail. Just tell them the problem, and they will issue a replacement as long as there is no physical damage nor liquid damage, for free, minus shipping.
Jul 31, 2009 | Sharp Cell Phones
That damn blinking light
If you can solder and know alittle about electronics, you can DIY
Jan 05, 2008 | Mitsubishi WS-55613 55" Rear Projection...
13 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
