Question about Kenmore Dishwashers
Water staying in the bottom of the dishwasher.
  • 4,350 Answers
WEll, there always needs to be some water remaining, but, you may have a blocked drain system, this means hoses, connections, screens. Needs to be taken apart and inspected to find.
Posted on Sep 09, 2010
Water leaking out from bottom of wdf780slybo dishwasher
I think that model had a problem with a clamp coming off the motor reinstall with a new clamp
Nov 08, 2013 | Whirlpool Dishwashers
Water is staying in the bottom
Water staying in bottom is not a problem unless the dishwasher base is full of it and covers the wash arm.
This means the drain cycle is not working or dishwasher is shutting off before drain cycle.
Try to clean the filters at the base and check drain in kitchen sink side is clear.
Need the model number in case you want more specific instructions.
Dec 06, 2010 | Maytag Dishwashers
Water stays in the bottom,how do I clean? Dave T
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 28, 2010 | GE Monogram® ZBD6880NSS Stainless Steel...
Does not drain, water stays in the bottom of the unit.
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 06, 2010 | Frigidaire Professional Series 24 in....
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Water stays in the bottom of dishwasher after cylcling
If the water is clean and only about an inch deep or less, this is normal and almost every dishwasher keeps some water in the bottom to prevent the seals / gaskets from drying out.
If the water is not clean and there is an odor, please report back here and we can take the next step. Is so, please note approximately how full of left over water the dishwasher is. OK?
Aug 03, 2009 | Dishwashers
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Some water stays in dishwasher (beau mark portable dishwasher
The manual says that's normal: "A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated."
Dec 14, 2008 | Dishwashers
Dishlex global 200 dishwasher. Eco button stays on and dishwasher continues to drain even without water. What is problem and how do I fix it?
bottom pan has probably got water in it. take off the bottom plate so you can see inside. disconnect from elec and mop water out and it will start. if problem re-occurs then you have a leak
Jul 13, 2008 | Dishwashers
Won't drain
The drian could be plugged or the pump could have an obstruction. Did you just install a garbage disposer? If you did you may need to knock out the plug in the disposer. Hope this helps
Jan 12, 2008 | Westinghouse 24 in. MDB421 RF Built-in...
Dishwashers Logo
67 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
