Question about Samsung SyncMaster 216BW Monitor
When I press the power button on my Samsung Syncmaster 216BW it goes to source test but does not turn off the monitor
  • 33 Answers
That is main board problem may be the EEPROM is defective could cause of cannot save or store current settings. You need to replace your main board to fix this problem.
Posted on Oct 02, 2010
Power button does not work
you must need to open the rear cover to access the part, then if you know how to test a tact switch using an analog tester just to know if it is worn out or no contact.
Aug 29, 2012 | Samsung SyncMaster 216BW Monitor
Syncmaster 216bw monitor..stuck in power saver mode..power light blinking
Did you try this monitor with another PC yet? VGA cable connectors are properly seated?
This model (same chassis as the 223w) is known for haing bad caps in the power supply/inverter board as shown here:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20223bw/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 26, 2011 | Samsung SyncMaster 216BW Monitor
Samsung 216bw does not turn on initially. It starts to, then goes black. If I turn it off and back on several times, it finally stays on.
The problem you are having is an indication of a failing power supply. There are parts called capacitors that fail and cause the power supply to not start up correctly. When you keep pressing the start button the voltages coming out of the power supply will finally stabilize and the monitor will display a picture until you turn it off then you have to start all over again. The power board can be easily repaired by replacing the ad capacitors. You can get information about the parts needed here: http://www.ccl-la.com/catalog/product_info.php?products_id=138 The repair will require you doing a little soldering but its very easy.
I hope this helps, if so please please rate our solution.
BuddyMc
Jul 06, 2011 | Samsung SyncMaster 216BW Monitor
Need Synmaster 216bw driver
Here is the driver download from SAMSUNG website
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=216BW&prd_ia_sub_class_cd=P
Just click on the driver, it is the same one as you listed '20070515103345609_SM223BW'
No need to uninstall the old driver, all the driver doese si to allow you to set the resolution that is not listed in the microsoft video resolution lists.
http://s807.photobucket.com/home/budm/allalbums
Jun 29, 2010 | Samsung SyncMaster 216BW Monitor
SyncMaster 216BW Monitor: it works for 1 hour suddenly the image goes and af...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Samsung monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 216BW Monitor
Samsung syncmaster 216bw problem scrren flickers and goes black
More likely to have caps failure in the power supply just like other failed SAMSUNG monitors here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you further.
Mar 24, 2010 | Computers & Internet
Monitor shut down by electrical breaker being tripped. will not restart
Test the outlet with another device for power, like a lamp or vacuum.
If they work then at least the outlet still has power.
Try totally unplugging it. Then plug it back in while holding the power button down.
Sometimes monitors can reset by holding the power button down for about 15 sec. Something should indicate a sign of life.
Still not working! Might need a new power inverter board.
Mar 09, 2010 | Samsung SyncMaster 216BW Monitor
Where I can get part for 216bw Samsung
thanks but The monitor was checked, the technician told me that he tryed to get the video card of the monitor Samsung 216 BW but they don't know were buy a part like this to replace it the broken.
If you can please, let me know where I can buy parts of Samsung monitor 216 BW.
Thanks.
Sep 25, 2008 | Samsung SyncMaster 216BW Monitor
Power button
I found this tread on another forum. I found it may help you to read it for you monitor problem. It makes sense to me so I'm passing it on.
http://www.daniweb.com/forums/thread17104.html
Sep 20, 2008 | Samsung SyncMaster 216BW Monitor
My Samsung 216BW is dead I think?
It seems it is the power suply, because some componets inside make that noise that you said.
Or It may be the power cord so be sure the 120 volts are passing some time it can be break in the base rear the monitor.
The probelm is that I don't now where you can get the parts taht you need for your monitor.
I hope it helps you.
Leo Trujillo.(Trumillon)
Sep 16, 2008 | Samsung SyncMaster 216BW Monitor
Samsung SyncMaster 216BW Monitor Logo
191 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
