Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Bosch dishwasher model she44c02uc goes through the whole cycle and will go on and on while timer shows 1. I got to press cancel drain buttons for draining and terminating cycle. What goes wrong with this machine?
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display like yours ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
...hence the unit sit`s and takes longer
Posted on Sep 15, 2010
  • mickel544 Oct 07, 2010
    Fixya.com and MacMarkus are the best! This reply helped us fix our Bosch dishwasher. Exactly the problem and the fix was relatively easy to accomplish. BTW, our original problem may have been caused by a hot water heater not delivering hot enough water to the unit. Just my thought: perhaps the heating process in the Bosch overworked itself trying to make up the difference. Thanks Fixya and MacMarkus.
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Regards,
BElectric
Mar 16, 2011 | Bosch Dishwashers
Bosch she44c06 will not stop draining, what is key selection to reset and continue using machine
on mine I have to push 2 buttons at the same time for 3 seconds to cancel cycle.Check your manual under cancel cycle. However you may have a problem discussed at this link:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Oct 31, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dishwasher model shx33a can't figure out how to just drain without running the whole cycle...HELP
usually on the consol in small print it will say press these 2 keys to drain. Read all the lettering on the consol and let me know
May 28, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
1,047 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
