Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Recently I have noticed that the seal on the refrigerator door is not very strong. I checked the seal for dirt and cracks and all looks fine. It is almost like the magnet is broken, but I know magnets do not break, unless it is an electrmagnet that is activated by a switch when the door is closed.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 11, 2010
The upper refrigerator part of our unit is iceing up?
Make sure the door seal is sealed tight all around the door. Most icing problems occur from the door seal leaking which lets moist house air escape past the door seal and gets sucked into the refrigerator/freezer. The moisture turns to water and then ice. Look for a crack, cut and seal bent over on itself ( not flush). If anything like this is noticed you'll need a new one. The good thing is they're not that hard to replace.
Oct 04, 2014 | Samsung Refrigerators
Refigerator door doesn't stay sealed shut
Check the seal condition for any damage, crack and etc. Ensure you check the whole seal. Clean the surface (seal and the contact) from any dirt/oil and etc.
Sep 24, 2007 | Sub-Zero 650 / O Bottom Freezer...
Model #79575543401 KENMORE ELITE Refrigerator The left side double door leaks at the bottom into the interior of the fridge. There is a panel on the inside of the bottom of the door, but not sure how...
. Using a good light , flashlight , etc. check your refrigerator and freezer door seals . This is the gasket that seals the door shut when closed . Look for cracks, tears, and possibly bumps in the gasket material. If you notice any of these , replace the door seal gasket . Furthermore , it is always best to replace both door gaskets at same time .
Feb 19, 2011 | Refrigerators
Freezer door pops open when the Refrigerator door is being closed
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Jan 08, 2011 | Refrigerators
Every time the refrigerator door is closed, the freezer door pops open. How can we better secure the seals?
Dec 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
Frost forms on seal and edges of freezer and at the upper rear of compartment
Try Cleaning the seals and the seal surface if the seal is old and cracked it could cause the icing problem. if there is dirt on it it will not allow the door to seal properly and cause this condition, the warm air enters the unit and sucks the moisture out of the air, and since you did not mention a make or model their is nothing I can do to help. You can buy a replacement seal get back with the make and model and I will give you a web site to look for a price for the seal.
Aug 06, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
550 Door Seal Doesn't Seem to Be Working
Since the doors on most refrigerators are adjustable, check the alignment of the door by pushing it close to being closed and seeing if the crack still visible is consistent around the three sides not yet in contact with the frame. These normally don't change much over the life of the unit but you may be able to improve the contact through an adjustment. Considering that the door does not seem to want to stay closed, check too on the hinge side to see if that part of the gasket is striking the frame too early.
Jul 23, 2008 | Sub-Zero 650 / O Bottom Freezer...
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
87 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
