Question about Boating
Hello, I have a 2001 Suzuki 5hp outboard. 2 stroke. It pours gas out of carburator overflow hole. It is a new carb that was put on. problem was the same with original carb. I have cleaned the whole fuel system out and problem still occurs. Any info would be greatly appreciated. Been driving me crazy as to why. Thanks
    Master:
  • 501 Answers
So your saying that when the motor is attached to yr boat,and in a vertical position,petrol comes out of the overflow hole?I would put a fuel filter in the line before the carbie.clean out the needle valve,and see what happens.check float height while bowl off
Posted on Sep 21, 2010
  • Ian Summerfield
    Ian Summerfield Sep 21, 2010
    I see Im no longer a Guru
Check the needle valve that the float holds in position is free to move if it is check the float is working OK ie.whole and intact.
Posted on Sep 09, 2010
  • loire Sep 10, 2010
    Been thinking about your problem and its unlikely to be the carb seeing as tho its new so have a look at the petrol tank there is a vent normally in the filler cap and if it isnt opened or is blocked then its possible the tank could become slightly pressurised if maybe its left in the sun when you go out ,for example ,and that would tend to push petrol into the carb .?
Cleaning a Echo PB-250 blower carbureator
Just like every 2 stroke engine. Take carb off, take off both ends and clean. Count the H and L adjustment screws turns so they can be put back the same amount of turns. Take out and clean holes
Jul 09, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
Overflowing Carbs again!!!
recheck and clean /adjust floats pet **** doesnt stop fuel in bowl if floats out of adjustment or valve sticking/debris will allow fuel to constant flow
Jun 04, 2017 | Suzuki Motorcycles
Problem with a tiller Earthquake viper engine either the carburator or carburator gaskets LBLSNMC43
The Viper Engine is a Honda clone. Try a new carb for $15 0n ebay. http://www.ebay.com/itm/NEW-GX160-5-5HP-HONDA-ADJUSTABLE-CARBURETOR-WITH-FREE-GASKETS/121225345625?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30002%26meid%3Df495007fc18649159ceb1009031e4fad%26pid%3D100011%26rk%3D2%26rkt%3D10%26mehot%3Dpp%26sd%3D261393057447
Mar 04, 2013 | Ardisam Inc Earthquake Mini Cultivator
I have a 2004 yahama 4 stroke outboard motor... when I crank it up the gas flows into the crank.I have replaced the all the carb. needle and the fuel pump with shows it is pumping at 3 pounds... The carbs...
Have You Changed The Diaphram In The fuel Pump It Sounds Like The Diaphram Has A Hole In It And Fuel Goes Directly To Crank Case Through the Pulse Hose
Feb 18, 2013 | Boating
Carburator is over flowing
I have a 98 V star same thing happened carb float is stuck i drained mine tapped on them a few times and has ran fine after running cleaner with the first tank of gas
Jul 02, 2012 | 2001 Yamaha V Star 1100 Classic
Gas leake from Air vent hose ( rear carburator) Suzuki Marauder VZ800 2002
If you mean that fuel runs out of one of the vent lines, note that one of those lines is for overflow from the carb bowl. If this is what is happening, you might have corrosion or dirt making your float needle stick, and overflow fuel to that carb. It needs to be cleaned out by removing the bowl, float and float needle.
Sep 06, 2010 | 2000 Suzuki VZ 800 Marauder
Leaks gas from the carburator.
Hi, Morgan_honda and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
2003 YZ125 Carb Overflow Hose Is Leaking Yamaha 2 Stroke
Oakys Garage How to clean overflowing Carb Carburetor Part 1
YAMAHA YZ125 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jun 19, 2010 | 2003 Yamaha YZ 125
Gas overflow line coming from carb is pouring out on a 2001 kaw
The float is stuck in the bottom of the carb. Remove the bowl, pull out the float and needle valve, and clean the valve and the hole it sits in.
Jul 08, 2009 | 2001 kawasaki KLX 300
Boating Logo
387 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
