IP address for Westell Router 327W - Computers & Internet
  • 109 Answers
The default IP is 192.168.1.1. If doesn't connect you will have to reset the router with the button on the back.
The default username/password is admin/password.
Posted on Sep 09, 2010
Need to open port 443 on my westell 327w how do i  do it
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on NAT then click on port forwarding .Then allow prot 443 it is for https then save settings and restart router .
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 05, 2010 | Westell Wirespeed VersaLink...
I need an IP address for my Westell 327W router.
Hi froggysmz321,
The best way to determine your IP address is to click start run and enter cmd then at the dos prompt enter ipconfig /all which will bring up all the IP address associated with that machine. The IP that your looking for is called the Gateway. Next to that is your routers IP.
Good Luck,
And don't forget to leave a rating.
Thanks
Mark
Oct 07, 2009 | Westell Wirespeed VersaLink...
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
May 29, 2009 | Westell Wirespeed VersaLink...
Want to use westell 327w as access point only
Yes, you can try to set up your network as follows:
  1. Unplug the second (Westell) router from anything and power it on.
  2. Reset your second router. Press and hold the Reset button on the router for 10-30 seconds. This will return the router to its factory settings and avoid any complications from the set-up you might have had when the router was being used as a primary router
  3. Connect one computer to the router. Do not connect the second router to the first at this time!
  4. Configure the second router at http://192.168.1.1/ (Check you manual for details. Usually the username is "admin" and the password is either blank or "password".)
  5. Change the LAN IP address of the second router from 192.168.1.1 to a free address within your LAN (see what IP range is used by your first router! If it using the same range (192.168.1.xxx) then 192.168.1.2 should be O.K.). The address you change to (192.168.1.2) must not be used by any other device with a static IP address in your network nor should be assigned by the DHCP server your network. A default Linksys router uses 192.168.1.1 itself and the DHCP server assigns 192.168.1.100-149.
  6. Turn off the DHCP server on the second router. (This is important, otherwise you end up with IP conflicts!)
  7. Save your settings.
  8. Unplug the computer from the second router.
  9. Connect an Ethernet cable from a numbered LAN port of the first router to a numbered LAN port of the second router. Do not use the Internet/WAN port on the second router!
  10. Start up the first router if necessary and reboot the second one as well.
  11. Voila!
The only problem I can see here is that your first router - now in charge of security - does not see your wireless clients as wireless, because they connect via an Ethernet port. Because the second router is connected via a LAN port, it is not using the router functions (DHCP, security, etc.) That might be ok with you - I'm just pointing it out.
If this doesn't work for you, just come back here, leave a comment and we take it from there.
Good luck and thanks for rating!
Apr 02, 2009 | Westell Wirespeed VersaLink...
Using westell versa link 327w unable to use wireless laptop
You may have your ip address set to manual. If it is, change it to automatic settings. This will allow for the airport wireless to give you an ip address. From there the airport's internet page should come up and you should be able to go from there. If it is set to automatic configuration, it may be a problem with the airport's router configuration. Sometimes a router only lets a certain amount of ip clients to be used per day. If that's the case, they may all be used up for that day.
Dec 09, 2008 | Westell Wirespeed VersaLink...
Westell model 327w router
if this is the first time you're trying to connect your laptop with the gateway, if this is a windows operating system, you have to go to your wireless zero configuration so that windows can automatically configure the wireless connection of your laptop. you cann see that by clicking on start, and then run, and then type in the box services.msc, and then search for wireless zero configuration click on start if the service has not yet started. if this doesn't work check your built in wireless adapter, uninstall and reinstall it. try to access your westell by typing in 192.168.1.1 in the internet explorer address bar. the default username and password for that is admin and password. you can configure the wireless settings in the modem by going here. the WEP key for your wireless connection can be found below your westell modem/router. if i'm not mistaken this is the westell 327 versalink right? you can also find out if your laptop is connected to your modem by checking your computer's ip address. it should be 192.168.1.xx. if it's like this, your laptop is connected to your 327w. if it's a 169.xxxx ip address, you're not connected to the modem. the best way to configure your laptop and modem wirelessly is to configure it while you're connected using an ethernet cable.
Oct 21, 2008 | NetGear DG834G Router
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
VPN through Westell Versalink 327w
do you have login access into the Modem/Router?
if yes, look for port forwarding and set it to your IP of your computer. open port 500 or what ever is required by MS fro the VPN
Nov 01, 2007 | Westell Wirespeed VersaLink...
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
