Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
There is power to the Book but it is not reading on the computer. I have tried different computers and wires.
  • 1,472 Answers
Hoopnu
If drive is no longer showing up I would double check in Disk Management to see if you need to reassign the driver letter. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If the drive does not show up then most like the controller card for the USB connection has gone bad. If you are still in warranty I would contact Western Digital about getting an RMA for the drive. If you are out of warranty then you should be able to pull the drive out of the encloser and connect it directly to you computer to access the data.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 16, 2010
Find address book for Christine
Come on, if you didn't write this and just read it right now, would you have any idea what you talking about ???
Address book - I assume you are referring to an email program, but which one, there are hundreds.
What operating system are you using, different ones store things in different places.
Is Christine the only user or are there other user accounts on this computer.
Mar 05, 2017 | Book Computers & Internet
Need a wiring diagram for a 2006 chrysler grand voyager
The first thing you need done is to have the BCM module read for fault codes. The instrument clusters in these vans are fraught with problems, they are a computer and all displays are computer generated with data from the PCM and BCM control modules. Sorry but a wiring diagram will tell you nothing, the testing is what is needed. If you still want to have the diagrams go to Ebay motors and try and find a used factory wiring diagram either on CD/DVD or in book form. The wiring diagrams are broken down into the different systems of the car. like lighting, Climate control etc.
Jun 09, 2016 | Chrysler Cars & Trucks
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
I tried to use the SwissKnife soft ware to create a partition on my WD my book essentials 2TB external hard drive. How ever I couldn't find any instructions under help, so I played around and did some...
First thing that you can try here is to connect the drive on a different USB port on your computer if your computer is a desktop better connect it on the back USB port of your computer and then while its connected restart the computer and then now check if it be detected.
But if still not better if you can test it out on a different computer so we can see if it will be detected or not on a different system.
Jun 16, 2011 | fdsfasf CompuApps SwissKnife V3
MY WD can't recognize by my pc but last week i use it but there no problem but when i plug it again today in my pc the book are not be read and theres no icon that can be seen in the HARD DISK DRIVERS BUT...
Device Manager only says that the disk is getting AC power, and that the "data" cable is connected, and that Windows has recognized the specific device-information (that it is a disk-drive, and that the capacity of the disk-drive has been recognized).
Device Manager does not say that the "spinning" part of the disk-drive is still spinning, nor that there are any I/O errors (trying writing with a pen onto greased paper -- not everything you write can be read).
Try connecting the MyBook to a different USB port on your computer.
Try connecting the MyBook to a different computer.
If it still is not "readable", then you have a few options:
* if the warranty still is valid, exercise the warranty, to get it repaired/replaced,
* disassemble the case, disconnect the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a "slave" drive in some desktop computer, to see if the USB-to-disk-drive adapter has failed
* buy a replacement disk-drive, connect it to that USB-to-disk-drive adapter, and close the case, to create a "new" external disk-drive.
Oct 24, 2010 | Western Digital My Book Essential 1TB...
My computer froze up one day. The green light on the mobo stays lit all the time now. I've replaced the cpu, RAM and tried different video cards, but it still won't boot up. I even got a different ASUS...
I think you have just about covered everything by testing the hardware out on a different system. The only vital thing that you haven't checked is the PSU (Power Supply Unit).
Get another power supply of the same type and try that in your system as faulty PSU's can cause these problems even though the motherboard is showing that power is being received, it could be showing a false positive.
Please let me know how you get on and if i can provide anymore assistance.
Regards.
May 28, 2010 | ASUS K8V-MX Motherboard
Hi i have a WD mybook both the lights on the power cord and the device itself are flashing rapidly and i am unable to acess the external drive. i have tried using a different computer, tried a different...
Hi I have the Essential Edition WD My Book 1TB/To, it was working well and then for no reason my computer does not recognise that it is connecte, now I can't access this drive was the g/ drive. Any clue as to what I should do?
Thanks
Dec 11, 2008 | Western Digital My Book Essential Edition...
Computer suddenly not reading external harddrive
I managed to fix it by unplugging the harddrive from the main electrical power source.
Nov 23, 2008 | Western Digital 500GB My Book World...
Wester Digital My Book 1 TB problems
Try booting your computer first and then connect the usb cable to the usb port on the computer. Connect the power supply cord directly to a wall socket. Also try the usb cable on different usb ports on the computer. If possible also try it with a different usb cable. If nothing works, check the file format system under disk management, you might have to re-format it.
Aug 10, 2008 | Western Digital My Book Essential Edition...
When I turn on my tascam 2488mk there's a message that reads...Cannot book!! Not detect hdd correctly please power off and check h\w.
well id say the hard-drive is not properly connected inside the computer to the motherboard. usually two cables that connect it one looks like a strip of mutiple wires usualy wide, and the other is a power cable that connects to the power supply. try removing the strip cable and reinserting it.
Aug 03, 2008 | Computers & Internet
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
62 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
