Question about GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator starts for 3-5 seconds then it stops running. After 4-5 minutes or so, it starts again and it does the same thing. It goes on and on like that. The ref and freezer is not getting cold. Light's working properly. Thanks.
  • 101 Answers
Moyher board
Posted on Sep 10, 2010
Fridge appears to be dead. No lighting, no temperature display, silent. When unplugged and plugged back in, everything functions as it should...for a couple minutes! Then it goes silent and dark again
call a technician as it could be a control board problem or a start run capacitor that is over loading the electrical side and throwing the thermal overload switch
May 20, 2016 | Refrigerators
My watch is 3 hours and 5 minutes off its a shp8948
1. Since all of the settings seem to go through the start/stop button, hold it down for three seconds to put it in "set the watch mode" (when the seconds at the bottom start blinking).
2. Do a quick press of the start/stop button to move from seconds to minutes to hours to years to months to days. The mode button subtracts & the reset button adds.
3. Setting alarms & so on require putting it alarm mode via the mode button. Use the reset button to move to the selected alarm (1-5).
4. Hold the start/stop button for three seconds to "set the alarm mode."
5. Quickly press the start/stop button to between things to set (kind of alarm, hours, minutes).
6. Again, the mode button subtracts & the reset button adds.
7. A three-second press of the start/stop button exits the setup mode.
Feb 27, 2015 | Watches
After highway driving for 2 hours and stopping for gas the car would initially start and then stall, it would run again until the car cooled for 30 minutes.
Sounds like your coolant level might be low. At highway speed you probably have enough coolant and with the air passing thru the radiator keeps the temp down, but at idle not so much. Or depending whether you have a belt drive or electric fan. Belt driven, could need a new belt.
Apr 06, 2017 | 1991 Mercury Colony Park
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
Switch on fridge and compressor runs for a few seconds and then stops, switch off for a few minutes and then switch on again and it runs for a few seconds. Checked thermostat and seems to be OK
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | AEG Refrigerators
Nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 10, 2011 | Amana Refrigerators
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Won't run continuosly.
The first thing that I would look at is the compressor relay. The relay gives extra windings in the motor, power to get the compressor up to speed. It is a small thing that carrys a heavy load. (MORE)
Jul 07, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Fridge compressor problem ?
Seems to me you have a faulty cold control. (behind the temp control).Not too expensive , about 40 bucks.
Feb 23, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
