System tries to boot but will not complete POST and shuts down. Any advice, please?
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Posted on Sep 19, 2010
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
Can't boot system shuts down immediately
The hard drive has failed and needs replacement.
Feb 23, 2014 | Acer Aspire 5742Z-4200 Notebook
Acer aspire will boot up then i shut it down if i try to switch this back on straight away the acer screen appears but then goes blank and does not load
I am quite sure the operating system is corrupted. Just install fresh operating system.
But still you mention, that it is booting up but it is just blank screen or shut down.
Try to press F8 key once when start up boot to go to ADVANCE BOOTING OPTION. If you are lucky, it will load this option and choose LAST KNOW GOOD CONFIGURATION. or if you have the Operatins system installer CD, put inside the CDROM and repair the operating system.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 12, 2011 | Acer Aspire 5920 AS5920 Notebook
Laptop shuts down after 20 or 30 minutes with one
Please refer to manual and run system restore to system default settings as if it was from the package.
Cheers.
Jan 24, 2010 | Dell Inspiron® 1501 (N11157) PC Notebook
My previously healthy Thinkpad T42, will not post.
The Thinkpad T42 doesn't have a reset button on it like the older IBM's used to.
There could be a problem with the battery. With the machine turned off remove AC power and then the battery. Plug in AC power again and see if the laptop will boot without the battery.
If it boots let it load up as normal and then shut it down again, reinsert the battery and try to boot it up. If it boots fine, if not then there is a problem with the battery.
Please post back if you need anymore advice.
Good luck.
Jan 14, 2010 | IBM ThinkPad T42 Notebook
My Acer Aspire 9504 boots to windows, then shuts down
it is quite a common problem with acer when they age. If youve replaced all the recommended parts and its still failing, then my only suggestion would be to try to boot it up, and press alt and F10 (THIS WILL WIPE ALL INFORMATION ON THE ACER) so if you have files programms ets that you need they would be lost. Alt F10 Instructs the acer system to Factory reset. If you do this, it will go back to factory standard, so it will go through the origional set up like it did when it was first purchased and you will need to spend some time doing all your windows updates once the install has completed.
Hope this helps.
Thanks
Oct 07, 2009 | Gateway M350WVN LAPTOP KEYBOARD COVER...
My inspiron e1505 has the numbers lock light lit all the time and the caps lock and the lighting bolt next to it flashes for a while and nothing happens. Then the computer shuts down. Help please
Try taking out the battery and booting it on AC power only, if the laptop boots let it boot up then shut it down and reinsert the battery and try boot again. If it doesn't boot up then there is a problem with the battery.
If it doesn't boot up at all post back.
Good luck.
Aug 18, 2009 | Computers & Internet
Philips LS1400 - Boot Sector Virus switching itself off randomly
Richt click on the hard drive -> choose properties->In properties window click on tools tab->in error check column click on check now->just check both the check boxes on check disk window- then click on start->after check completes restart your computer
Jun 19, 2009 | Microsoft Windows XP Media Center Edition...
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
Fans runs but no post,no beeps.
The best advice I can give you is to remove the motherboard battery (UNPLUG THE PSU BEFORE YOU WORK ON THE MOTHERBOARD) and let the system sit for about an hour. If the CMOS settings are corrupted, removing the battery will erase the corrupted data in the CMOS, which will automatically reset the CMOS to the default settings... Then, plug the battery back into the motherboard, and try to boot the system...
If that doesn't work, you should disconnect EVERYTHING attached to the PSU, and remove ALL of the add-in cards (modem, NIC, soundcard, TV tuner, whatever you have), and install ONLY the CPU, the heatsink/fan (don't forget to PLUG THE CPU FAN IN), ONE stick of RAM... you get the idea. DISCONNECT the HDD, the FDD, the optical drive, and ANYTHING ELSE from the PSU. When you're ready to test the system, you should have ONLY the CPU, the HSF, and one DIMM plugged into the motherboard. Attach the PSU connectors (both the main ATX connector AND the auxiliary 4-pin 12-volt connector) to the motherboard, and try to boot the system. If it works, SHUT DOWN and UNPLUG THE PSU; then install ONE component (the floppy drive, for example), reattach the PSU, and reboot the system. If the system POSTs, shut down, unplug, and add another device. If the system does NOT complete the POST process, the last piece of hardware you installed is probably the culprit.
Take your time with this; be methodical, and make GOOD notes about the steps you've followed, so we can help you work through this problem...
Best of luck to you; keep us "posted" on your progress...
Jan 27, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
