Question about Panasonic Microwave Ovens
Model NN-ST477 Microwave Oven door does not lock, so it cannot be used
MicrowaveSvc
  • 9047 Answers
SOURCE: panasonic microwave oven model nn-p994sf
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 22, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
  • 4 Answers
SOURCE: my microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Posted on Nov 08, 2008
  • 178 Answers
SOURCE: Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Posted on Sep 13, 2009
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
Light nn-sa651s
Panasonic FAQ:
The microwave oven model NNSA651S was manufactured in a way that the oven light turns on only while cooking. - FT
Stupid design!!
Feb 19, 2013 | Panasonic NN-S541 Microwave Oven
DOOR WILL NOT CLOSE ON NN S752 WF PANASONIC MICROWAVE OVEN
it looks like theres a faulty door lock mechanism have it checked out and replaced!
Sep 25, 2011 | Panasonic NN-P295SF Microwave Oven
Door button does not function for panasonic microwave=need to know how to take the face off so that I can fix it
Take side panels off and press the button through from the back, my husband has just done this tonight on our Panasonic microwave model NN-ST477 as the door would not open. He found a piece of plastic like a hook had snapped off. The door now opens and functions normally. Took about 30 minutes to do . If and when it becomes stuck again we know that we will need a new replacement button. Hope this helpskind regardsChristine
Sep 14, 2011 | Panasonic NN-H275 Microwave Oven
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
Our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Mar 27, 2009 | Panasonic NN-S252WF Microwave Oven
Door
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
If you reply back to this with your brand and model number, we can steer you toward a part source, and possibly toward exploded view diagrams, etc.
Jun 22, 2008 | Panasonic NN-H275 Microwave Oven
Microwave NN V622m locked
To lock, press START 3 times. To unlock, press STOP/RESET 3 times. If this doesn't work, contact Panasonic Support at http://www.panasonic.com/support/
Mar 26, 2007 | Panasonic NN-V671S Convection Microwave...
Microwave Ovens Logo
59 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
