Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
I have a few horizontal wavy lines at the top of the screen when I first turn on the TV. They eventually fade after a few minutes. What's going on? Is this serious?
  • 505 Answers
Yes it is, your hyper board has bad caps and they will just get worse and worse. you can run it on an HD signal to keep it going longer but eventually even the HD will have the wavy lines too.. basically the hyper board needs new 10uf 16v surface mount capacitors, replace all those and your golden, but its a difficult repair, even for a educated and seasoned electronics tech, estimate from repair shop will run you $250-$550
if you can solder surface mount, you can fix it yourself for like $20
let me know if I can provide further assistance
Posted on Sep 09, 2010
    Scholar:
  • 119 Answers
I would suggest using it till it dies, I have had the same problem with mine for 2 years, and its still working, After 3 minutes they fade away, For the price of fixing it we could buy another
Posted on Sep 10, 2010
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Jan 17, 2009 | Prima CV2011 TV
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Horizontal lines when I first turn on my Pansonic 51" PT-51HW41 Projection TV
It's probably failing capacitors, does it squeal while this is happening?
Jan 14, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
203 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
