Question about Thermador C272 Electric Double Oven
Thermador 227N Double oven. Error Code E10 (after
Thermador 227N Double oven. Error Code E10 (after a brown out) Reset circuit breakers 10/20/30 minutes. still E10 Micro works, lights, fans etc. Tweaked the nubs as suggested in owners manual. E10
Master_Tech
  • 770 Answers
SOURCE: f7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
Posted on Jan 27, 2008
marked
  • 6487 Answers
SOURCE: Thermador C302U error code
From my experience when there is a power outage, This is likely to have wiped out the control board on your oven. I see it all the time after storms. If a storm comes through, I get a ton of phone calls about control boards not working anymore or doing crazy stuff. If resetting the breaker has shed no light on your situation. I would recommend replacing the main control.
Also when you get this fixed, plug the stove into a surge protector of some sort. This will decrease the chances of a power outage doing damage to the oven control.
Hope that helps........
Posted on Jun 28, 2008
localwonder
  • 6784 Answers
SOURCE: Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Posted on Dec 08, 2009
SOURCE: Fan works, but Oven stays at 100 degrees. Tried
On my C301 U, I found the brown connector on the right side of the oven control board P3-2 loose. It looked connected but while doing a shake test- Whoop, there it is. It is the sensor for the temp probe. If it's loose all the fans run all the time.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=C301U&productCategoryId=0124100&brandId=1085&brandDescription=THERMADOR&modelName=BUILT-IN-OVENS&diagramPageId=00014&componentDescription=WIRING%20DIAGRAM&documentId=U2500861&blt=06
Posted on May 23, 2010
tunde007
  • 2382 Answers
SOURCE: Error code F64 on lower
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Posted on Nov 12, 2010
Have a "CAL" error code. Reset fuse box breaker. No code, but nothing is operable.
try rebooting; unplug or switch off the circuit breaker for 90 seconds
Mar 26, 2016 | Thermador C272 Electric Double Oven
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Jun 28, 2008 | Thermador C302U Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
Dec 08, 2009 | Ovens
Probe light stays on so I can't cook
Hey i just got knocked out of the session can you please get back in to the session
Nov 26, 2009 | Thermador SEC272BPSS Electric Double Oven
Thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
Sep 11, 2009 | Thermador SMW272 Electric Double Oven
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
F 34
My Name is Don from Mr Fix it Applaince in baytown texas. I have seen this F34 error as well and may have a solution for some of you... According to a Thermador error code book for a C301bs/03 single Thermador oven. It says its a air flow problem. This means it could be the fan motor sensor telling the controlboard that it is not spinning fast or not at all. or it could be a micro paddle switch that is activated by air flow, I found Two of them on the bottome of a double oven thermador a few moths ago.. Recap : if your fan blower motor has 4 wires going to it, it has a sensor reading the rotation of the motor.... if yours does not have this then you should look for a paddle switch.
Mar 10, 2008 | Thermador C301U Electric Single Oven
Thermador C272 Electric Double Oven Logo
230 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
