Question about Danby 35-Bottle Wine Cooler - Black DWC350BLP
My Danby Wine Cooler DWC350BLP is runing too cold for red wine. I need the factory settings to be 5 degrees warmer. The minimum setting on the thermostat does not do the trick. Thanks,
Demy
  • 20 Answers
SOURCE: danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Posted on Aug 01, 2007
Joe_Rex
  • 114 Answers
SOURCE: danby wine refrig
THE LAST THING THAT EVER HAPPENS IS FREON LOSS.
SO TRY THIS FIRST ...
LET THE COOLER STAND WITH "NO POWER FOR 24 HRS.
MAKE SURE IT INSIDE AT ROOM TEMP. NO HIGHER THAN 75 deg. AFTER THE ALOTTED TIME TURN THE T-STAT-"OFF" AND TURN THE POWER "ON" ...
THE CONDENSER FAN SHOULD START IMMEDIATELY. NOW LISTEN REAL CAREFULLY BY THE COMPRESSOR TO HEAR ANY CLICK NOISE. IF YOU DO THAT IS THE EXTERNAL OVERLOAD ( bI-METAL SAFTEY T-STAT THAT PROTECTS THE COMPRESSOR. TURN POWER OFF AGAIN AND DO THE FOLLOWING.
THERE IS : 1) A START (plug-in) RELAY THAT PLUGS INTO THE COMPRESSOR.
2) THERE IS A START ASSIST CAPACITOR MOUNTED USUALLY ON THE TOP OF THE COMPRESSOR TEREMINAL COVER.( THIS IS HELD ON WITH A METAL STRAP THAT CAN BE "POPED-OFF" WITH A SCREW DRIVER. OR IT MAY HAVE 2 MOUNTING SCREWS.
3) THERE IS A ROUND BI-METAL T-STAT THAT PROTECTS YOUR COMPRESSOR.(AS STATED ABOVE).
MAKE A DRAWING OF WHERE EVERY WIRE GOES AND THE DEVICES ON PAPER. .... THEN ... AND ONLY THEN REMOVE ALL 3 PARTS AND TAKE THEM TO YOUR LOCAL APPLIANCE REPAIR OUTLET. eg. APPLIANCE PARTS. APCO ETC.
THEY WILL CHECK ALL 3 COMPONENTS FOR YOU AND MOST ALL HAVE UNIVERSAL REPLACEMENTS FOR ALL 3 DEVICES NO MATTER WHAT BRAND YOU HAVE.... AND THEY SHOULD BE ABOUT $10-$15 EACH.
I HAVE REPAIRED HVAC & REFRIGERATION EQUIPMENT FOR OVER 40 YEARS. WHAT I DO IS REPLACE ALL 3 DEVICES. IF ONE IS BAD IT TENDS TO OVERHEAT THE OTHER COMPONENTS AND WEAKENS THEM.
NOTE: NEVER INSTALL REFRIGERANT SELFTAPPING VALVES TO CHECK FOR FREON ... A AMP DRAW WILL TELL YOU IF COMPRESSOR IS RUNNING AT FULL LOAD , AND AT THE EVAPORATOR YOU SHOULD HAVE A 10-20 DEG F. DROP IN TEMP. YOUR EVAP COIL SHOULD FORM A EVEN FROST ON IT IN ABOUT 2-3 HOURS.
THE MAIN THING IS TO ENSURE COMPRESSOR IS RUNNING.
IF YOU HAVE A THERMOMETER, THE LARGER COPPERLINE ON THE COMPRESSOR SHOULD BE ABOUT 50-60 DEG.AND EVENTUALLY WILL "SWEAT". THE SMALLER LINE SHOULD READ 120-150 DEG "AT THE COMPRESSOR" OUTLET CONNECTION.
MAKE SURE YOUR CONDENSOR AND EVAPORATOR COILS ARE BOTH ABSOLUTELY CLEAN. (CHECK WITH SMALL BRIGHT FLASH LIGHT TO SEE THROUGH COIL FINS.
THAT SHOULD SOLVE YOUR PROBLEM. YOU MAY FIND WHEN TAKING THE PARTS OFF ... A BROKEN OR BURNT WIRE. IF SO REPLACE IT WITH AT LEAST #12 STRANDED WIRE.
PROPER WIRE AND TERMINALS ARE AVAILABLE AT THE APPLIANCE PARTS STORE IN YOUR AREA.
GOOD LUCK ... JOE_REX
Posted on Oct 12, 2007
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
SOURCE: E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Posted on Jan 01, 2009
ITS NOT COOLER ITS IS ABOUT 3YRS OLD
IF it is running now:
Check the "coils" along the bottom or back, and dust them off with canned air.
Check the seal along the door, it may have been sprung by opening all the way too many times. To check the seal, take a note card (or business card) and place it in spots between the seal and frame for the cooler.
IF it is not running or running very loud:
Unplug the unit and let it warm up to room temp (transfer the wine into several good cooler boxes first...) and then leave it for several hours, then start it up again, this should help.
Topbarhive
Jan 12, 2016 | Danby DWC350BLP Wine Cooler
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
My danby wine cooler does not get cold enough
Cool enough? You know most wine and beer only like it about 50 degrees and not any cooler. If it up at 55 and you have set it lower then the room is probably warmer then it can handle to cool them. I have some in the garage but in July and August the struggle to stay any cooler then 55 but then they are not expensive units either. Danby is cheap brand too. Nothing they make is that great.
Oct 07, 2014 | Danby Refrigerators
How do u set temp in a Danby wine frig?
Please have a look at page 4 of the product manual where step-by-step directions are provided for setting your desired temperature.
http://www.danby.com/cms/products/en_manual/DWC283BLS_%28web%29.pdf
If you have any further questions, please do not hesitate to contact Danby Customer Service via 1-800-26-DANBY
Hours of Operation Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
May 05, 2012 | Danby DWC283BLS Wine Cooler
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
Does not chill drinks
you wrote that the wine cooler "only cools to 12 degrees minimum" I don't understand the problem?
12 degrees is really cold, in fact its freezing.
Oct 29, 2008 | Sunpentown Platinum Trim Cabinet...
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Refrigerators Logo
78 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
