Question about Brother SE-270D Computerized Sewing Machine
My needle will not thread automatically. I tried to load some heavier thread and ever since then I cannot get it to thread the needle. The thread comes out when I push the cassette down, but it does not go into the needle. The machine works fine if I thread the needle myself.
    Genius:
  • 1,788 Answers
Call Brother customer service at 1-877-276-8437 and explain your problem, they maybe can tell you how to reset.
Posted on Sep 09, 2010
Iam sewing seats. but the threed stared braking at the needle & it want saw.
Most likely, it has to do with incompatibility of the needle, thread, and fabric. The force of the needle penetrating the fabric multiple times is actually causing the thread to (wear &) fray and eventually break. There are needles with larger grooves that tend to protect the thread during stitching. Some may recommend a Top Stitch Needle (Home Machine Needles Superior Threads Why Topstitch? The Topstitch needle is the most common needle type used and recommended by professionals and educators. We recommend the Topstitch for piecing, quilting, embroidery, appliqu?, and construction. These needles are available in four sizes to accommodate all thread types, including metallic threads. The Topstitch needle has a larger eye and deeper groove. It is often referred as the MAGIC NEEDLE. It really does make a difference in your sewing experience.)
Why Use Topstitching Needle
Also, if the thread is a tight fit through the needle eye, it will also tear the thread. Make sure that the thread will slip easily through the eye. Go to a larger needle, instead of 90, try a 100.
Be sure to use a brand-new needle.
All About Needles
The Parts of Sewing Machine Needle
You may also consider changing the type of thread you are using. Go with a stronger thread, ie polyester, rather than cotton. Cotton will shred and break easier.
You will probably need to re-adjust the thread tension. If it is too tight, it will also break the thread. If you are using a heavier weight of thread, you will need to adjust both the upper and bobbin tension to accommodate the heavier thread.
Bobbin Tension How and Why Tension is Adjusted
If you sewing fabric that is sticky, ie vinyl, oilcloth, you should try to use a roller presser foot, a teflon presser foot, or a walking foot to help the fabric move with the feed dogs.
Sewing Heavy Fabric with NON Heavy Duty Sewing Machine SEWING IN GENERAL
Tips
Sewing through many thick layers of fabric Sactin
http://www.kollabora.com/q-a/sewing-denim-and-thick-fabric
14 Fantastic Sewing Tricks and Tips Making the World Cuter
How to Sew Upholstery DoItYourself com
Apr 22, 2016 | Sewing Machines
Will not accept heavy duty thread. sews with bunch-up on bottom of material
the top thread tension is too loose
tighten it up a lot
Dec 12, 2015 | Sewing Machines
Can I sew canvas with a thicker thread and do I need to replace the needle with a needle with a larger eye? Nathan's, trudy
It probably depends on what machine you are using. What is the make and model?
Have you tried anything yet? Does the machine struggle to make it through the canvas at all or does it jam when you use thicker thread?
Jun 10, 2015 | Sewing Machines
Bobbin thread will not catch on heavier materials but will catch on lightweight
You need a heavier needle, and if you can adjust your presser foot to increase the pressure, that would be helpful too. The needle is just not getting through enough to catch the bobbin thread. The higher the needle number, the longer the needle.
Jul 28, 2014 | Singer Sewing Machines
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
Husqvarna lily bobbin tension issues
Not sure if I can help, but it may have to do with the heavy thread as well as the fabric and needle combination. If the fabric is thick or tightly woven, be sure to use a brand new sharp needle. (If the fabric is tightly woven (like Batik), a thicker thread may present a problem.) In your case, if using a heavier thread, perhaps a top-stitch needle would be beneficial since it has a bigger scarf to protect the thread. With the heavier thread in the top, the top tension will need to loosened. BUT, if you loaded the heavier thread in the bobbin, the bobbin tension will need to be adjusted to accommodate the thread thickness. However, remember that if you adjust the bobbin tension for this project, you will most likely need to readjust it for the next project using different materials.
FWIW, if the machine still works fine with regular fabric and thread, then you'll know that the issues revolve around the current project.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 11, 2017 | Husqvarna Sewing Machines
I have a Euro Pro Shark Automatic. It works perfectly as a rule. I am trying to sew heavier material than usual - new inserts for my exterior sling chairs. The thread is heavier nylon and it catches on...
Most domestic sewing machines will not handle heavier thread than the standard 50 weight. I'd suggest you go back to regular polyester sewing thread and use a 110 or 120 size needle to cope with the heavier fabric. Sew slowly and give it some help on the flywheel when crossing a seam allowance. Maybe stitch each seam twice, with a 1mm gap between to give it strength.
If you need to use the heavier thread to do the job then you will probably need an industrial sewing machine that can handle that grade of fabric and thread. Something like a Singer 20U machine in a table with seperate motor drive.
Fabrics like Canvas, ticking and PVC for exterior items are generally going to be beyond the functionality of a domestic machine and you can damage the machine, particularly the timing by trying.
Aug 23, 2011 | Euro-Pro Shark 80 - 7133
Tension botttom thread gobs up and then locks up
make sure the tension is reset to the type of thread you are using, less tension for heavier thread and the needle size larger thread for heavier thread
Dec 09, 2009 | Singer 3116 Simple
Brother SE-270D Computerized Sewing Machine Logo
66 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
