Question about Kenmore 24032\24036 Top Load Washer
Kenmore Model 70, #110-82372110 won't drain or go any further than drain in cycle. Motor is running but no draining. Lid switch is OK. Pulled drain hose to check it for plug and it is OK. When I pulled the drain hose the water in the tub flowed out so apparently no obstruction in pump. What next?
  • 87 Answers
SOURCE: DOES NOT DRAIN WATER
If motor runs or sounds like it is trying to run, you have a sock caught in the pump. If no noise at all you have a bad lid switch
Posted on Jun 08, 2007
ngfam1
  • 639 Answers
SOURCE: F21 error
Peace Friend,
ngfam1 At your service!
NO GOD FOR BID DO NOT USE DRAIN OPENER IN AN APPLIANCE!
First try this, unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 02, 2008
jumptrout51
  • 3361 Answers
SOURCE: kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Posted on Feb 26, 2009
  • 1122 Answers
SOURCE: Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Posted on Apr 24, 2009
Maytag317
  • 1136 Answers
SOURCE: kenmore 70 series, 110 washer leaks water when
Hi, You will need to change the inlet mixer valve. It is sticking open just enough to allow water to drip through it. This should be chandes asap so that it doesn't get bad enough to over flow the washer.
Here are directions on how to remove the cabinet so you can get to the inlet valve.
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 14, 2009
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore 300 model 110.28322700 won't run. motor makes humming sound
Pre Thanks for help.
I have read all above and these are my symptoms.
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
however i tested my lid switch with a multimeter and the lid switch seems to be fine.
What else could be my issue?
Kenmore 300 110.28322700
Dec 03, 2011 | Washing Machines
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore model #110.22802100 drains but no spin
If it is draining, then the motor is ok.
If it is agitating properly, then the motor coupler is ok.
This leaves the gearcase, clutch, basketdrive(brake), basket drive block, or timer.
Raise the lid and hold the lid switch down. Start a rinse cycle and let it go through the cycle. It should drain the water, then stop the motor for a split second then kick the motor back in and start spinning. If it doesn't drop out that split second then the timer is holding it in neutral drain. You can recreate this by letting it start draining, then let off the lid switch, then depressing it again. The basket should start spinning. If not,
Raise the lid and hold the lid switch closed. Start it in spin and see if you can get it started spinning by hand. If so you probably have a slipping clutch.
Post back with any questions.
You can go to sears.com, click on parts, and enter your model number and see parts diagrams of the washer. This can be helpful.
Nov 25, 2007 | Zanussi F1045W Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
