Question about GE Q Series GSS25QGT Side by Side Refrigerator
I have a gss25 Fridge and it has been no problem since 2005. This AM my wife was cleaning the refrigerator side when the upper lamp went out. I replaced the lamp and it still did not work. I tested the old lamp elsewhere and it was OK. Also, the lower lamp was lit. I then tested the upper socket with a meter and it was dead. My wife then closed the door after the cleanout and when we opened it again, it was lit. Is the door switch actually two switches or is my fridge haunted? Thanks
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
BNewberry
  • 93 Answers
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Posted on May 15, 2008
  • 54 Answers
SOURCE: GSS25 side by side refrigerator stopped freezing first and now refrigerator part doesn't stay cold. sounds like a fan is running but when I open the door the fan or whatever is running stops
Is there frost on the back panel in the freezer, If so change the defrost heater. If not is there anything running?
Posted on Jul 03, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
  • 16 Answers
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Posted on Mar 25, 2009
Why has my GSS25 ice maker quit working? Water dispenser is fine.
The icemaker could be frozen where the water supply comes into the icemaker this sometimes happens if the water was recently shut off or you had low water pressure. Unplug the fridge and try using a hairdryer to defrost where the waterline comes into the freezer. I would assume you already checked to see the icemaker was turned on and the bail was in the down position. If you did All things i mentioned plug in the fridge and test if it still won't make ice afterwards you will need to replace the icemaker. The replacement should come with instructions.
Aug 01, 2014 | GE GSS25JEMWW Side by Side
Was cleaning fridge and now lights wont work
Possible that the door switch had been tampered or is locked to stay closed and so the light wont be triggered. So check the door switch and finally the lamp holder and lamp. One of this was tampered when the cleaning was done. Can be a loose connection of the lamp, switch or holder, use switch cleaning oil to clean.
Oct 09, 2011 | Whirlpool GD5SHAX Side by Side...
Frost is building up in the GE GSS25 side by side refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 21, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
After a bottle of gin broke spilling it's contents in the upper portion of our bottom freezer Amana Model BRD18V2S, The refrigerator no longer gets cold, we have aired out the liquor fumes and although the...
My wife posted the information below and I would like to add more to the story: We have two identical Amana Bottom Freezer Refrigerators, Model:BRD18V2S installed in our Kitchen. Both fridges are in an alcove and stand next to each other. One fridge is used as the beverage fridge and othe other is used as a food fridge. At about 10pm she noticed that an entire bottle (600ml) of Gin had cracked and emptied into the refrigerator section of the fridge used for beverages. We do not know how long the spilled gin was in the fridge. She mopped it up and we went to bed. At 7am the next morning, the beverage fridge and its freezer were showing 71 Degrees F. and everythind including the ice had melted. (We have aftermarket external temperature gages that show the fridge/freesor temperatures) The food fridge uninvolved with the gin spill was reading 68 Degrees F
Sep 17, 2010 | Amana Refrigerators
Need new water filter housing.
could not find your moder # / but the gss25 uses a filter asm and tube pt # wr17x11618 cost( 51.50 ) also newer style filter pt# cwf cost 34.99 ) re ck your mod # on the machine ( do not use the instructions that came with it . any appl parts dist should have these parts .. they are very common .. mm ..
Dec 02, 2009 | GE GSS25SGRSS Side by Side Refrigerator
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Open Questions:
GE Q Series GSS25QGT Side by Side Refrigerator Logo
37 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
