Question about Bose Lifestyle SA-3 2-Channel Amplifier
I recently purchased a used SA-3 Bose Amp. The dip switches are in the factory default position and when plugged in the indicator light blinks every 3 seconds. I have the unit connected to the Lifestyle 50 unit with the A-link cable and the 9-8 pin adapter to the music center. The music center recognizes the additional room but when turning on "room B' the amplifier will not power up, just blinks every 3 seconds???
3 Suggested Answers
ongolo
  • 11 Answers
SOURCE: Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Posted on Mar 19, 2007
  • 3 Answers
SOURCE: we have just installed a Bose lifestyle system,
Make sure you unplug your sa 2 and sa3 amplifiers after setting the codes. Wait at least 60 seconds, then plug back in. I would also unplug the in and out boselink cables as well. Once youve waited for a minute, then plug everything back in. Should work. If not, call Bose technical support. They are really great. I have 15 SA 3 amplifiers throughout my home. They are great.
Posted on Apr 18, 2010
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
Hi, just purchased new Bose Solo sound system. But when plug power on, there is no "tones" to indicate power is on, just slow and constant twitch sound.
REad the instructions carefully. Take the uni back to where you bought it and have the salespeople explain how it's used. Call tech support for Bose on their toll free number.
May 29, 2015 | Bose Solo TV sound system - Black
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
My Bose SA-3 Amp is connected up right as it was working for months,now the green light is flickering different patterns and the remote wont work with it. It flickers fast,then slow, then in standby m
Unplug your Bose system for 5 minutes to reset the processor ic, now plug back in, if no change! contact Bose, this is a product that is only repaired on site at the factory and they have the parts.
Apr 23, 2012 | Bose Lifestyle SA-3 2-Channel Amplifier
I bought a Bose V35 2 weeks back. I played my system yesterday and switched off. Since this morning I am unable to switch on the system. Green light keeps blinking and I keep getting the message "iPod...
With this system being so recent from purchase you should return it to the store as it is faulty. DO Not Attempt to do any "Mr Fix It" type repairs as it will invalidate any warranty (standard is 12months from new in UK)
Jan 07, 2011 | Bose V35 Theater System
How can I conrol the volume of bose sa 3 amp from the aux input ?
That would depend on the preamp. Name it. A true preamp outputs a variable signal.
It's not clear from the manual what the state of the volume output is without the VCA. Most amps default to full ON and the preamp attentuates the signal with a volume control. Try it with a signal that fades in slowly so you can intervene if it gets too loud. If it's full ON a preamp will control its volume.
May 28, 2010 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose SA-3 amp and a non bose sub.. I keep blowing the amp..
How many ohms is your sub? The SA 3 Amp can only handle speaker(s) 6 ohms and greater. A lot of subs, as I understand, are 2 and 4 ohms typically. If yours is 2 or 4 ohms, then that explains it. The speaker would be "straining" your amplifier and blowing it.
Oct 02, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
SA-2 and SA-3 doesnt work together
its alwaays better just to call bose their great when it comes to this
May 20, 2009 | Bose Lifestyle 18 System
Bose lifestyle no sound
Hi, best practice when troubleshooting a no-sound Bose Lifesytle system is to first begin with the internal sources (i.e. the AM/FM). Bose Lifestyle system when connected properly (media center and bass box via the data cable) should show a steady green light underneath the bass module. Begin by simply playing AM/FM tuner and try to increase the volume till 45 (normally the sound becomes audible at this level). If the system still has no sound, then try to check if the bass module is steady green. When you see a blinking green LED (slow green) then do kindly check the DIP siwtch (red latch switch with white mini switches) just beside the Light and data connection. All of the switches should be in "ON" position (basically toggled upwards with the arrow marking indication). Before changing DIP switch settings do ensure that the bass module is not connected to the electrical power. after ensuring that all DIP switch are in the "ON" position, connect the data cable firs and then power up the bass module. Then you should see the bass module blink green twice and once you turn on the nedia center, the green blinking should turn steady green. That should sort out your problem.
Also do note tha this procedure applies only to Series II Lifesytle System and does not include the Series IV (with the smaller bass module).
If all still fails, there is an internal problem with the bass module which would require servicing.
Hope this helps!
Jan 27, 2008 | Bose Lifestyle 18 System
Hunter Remote Control # 27185
Do not use the factory default position in either fan. Double check the dip switches, and make sure they are the same for each individual receiver and remote.Different codes for each. Dip switches are the oppsite direction in the remote for some reason?
Jan 01, 2008 | Hunter 27185 Remote Control
Bose Lifestyle SA-3 2-Channel Amplifier Logo
170 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
