Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Have a whirlpool refrig. both sides freezing up even when set on lowest level model # ed5phaxtsoo cleaned coils fan runs allthe time.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
I have a two year old whirlpool side by side refrig and it is freezing things in the refer side no matter what setting it is on. Can you tell me where to start to troubleshooting?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Good luck in solving the problem......
May 12, 2011 | Whirlpool Refrigerators
I cleaned my Whirlpool SbS Model # ED25CQ coils underneath & accidently hit the fan & now it's not running. It seems the refrig & freezer are working so do I have to have a repairman out? Is...
You might have bumped the connector for the fan. yes you have to have the fan if the compressor is running, if not you will distroy the compressor.
Feb 20, 2011 | Whirlpool ED2SHAXM Side by Side...
Fridgerator is freezing everything even at lowest setting it is an whirlpool energy star side by side
Check the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Hope this helpout in solving your problem
Aug 01, 2010 | Whirlpool Refrigerators
Food freezes in the refrigator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
May 20, 2010 | Whirlpool GD5SHAX Side by Side...
The top part of the refrig keep freezing?
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Apr 14, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
ET21DMXDW04 TOP-FREEZER REFRIDGERATOR The fan
The evaporator fan should run all the time that the unit is out of defrost. The only time this fan is off is when the unit is in defrost.There are two pssibilities for the "snow", it is either the defrost timer or the defrost termination control. Change the defrost timer first, on 90% this is the problem. If not change the defrost termination control located on the refrigerant line leaving the evaporator coil.
Oct 31, 2009 | Whirlpool Refrigerators
I have a 6th sense whirlpool 25.6 cu with water
First , remove the kick plate and make sure the coils are clean of dust . lint , pet hair , etc . Then pull the refrig out and remove the rear lower panel , covering the compressor and cooling fan ( evaporator motor ) . Make sure this motor is working , if the compressor is running . If the fan does not work , then replace it as soon as possible . This fan , cools the coils and the compressor , which if not working , causes the divider strip to become extremely hot , and could cause the compressor to have problems , due to the heat . After removing the rear panel , be sure to re-install it , as this is there , to direct the air flow as needed .
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
