Question about Canon PIXMA MX320 Color USB InkJet Printer
The display screen keeps flashing 'Waiting for report' and my faxes are not going through. I have tried finding the setting that allows the reports to print despite my ink running low but have not been able to. I do not think the ink is the problem because this message has been on my screen before my ink started to run low.
    Top Expert:
  • Canon Master
  • 14,162 Answers
Posted on Jun 14, 2015
5 Suggested Answers
SOURCE: Cannon MX310 - Fax - Waiting for report
I had the same problem.
My INK Level was Low and I had the setting "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report would not print due to the ink level being low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed immediately, and the message will disappear.
Posted on Mar 20, 2009
SOURCE: canon mx700 fax report problems
after emailing canon support, the answer is this: 1) the fax paper size must be "letter" - 8.5-11". 2) reset all settings through settings menu. the fax will then print reports (and also every report that was not printed before).
Posted on Jun 14, 2009
  • 56 Answers
SOURCE: my fax (pixma mx330)says memory in use and shows
Hi, you must reset the machine in the factory setting mode.
Posted on Oct 09, 2009
shishirgarde
  • 114 Answers
SOURCE: On my Canon MX310, the display says
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Posted on Nov 17, 2009
How do I retrieve info from 3210/3220 work centre fax stored in memory
We encourage you to use our knowledgebase MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year! We can solve your problem!
Email patrick@mrc360.com for more info.
Solutions for : How To Print Reports Solution : Print Reports NOTE: Some report options may not be available depending on the product configuration.
  1. Press the [Menu] button on the Control Panel until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [OK] button.
  3. Press the [Left] or [Right] arrow button until "Reports" is displayed.
  4. Press the [OK] button.
  5. Press the [Left] or [Right] arrow button until the required report is displayed. The following options are available:
    • [Configuration] - This report lists the status of the user-selectable options. Print this list to confirm changes after modifying settings.
    • [Address Book] - This report lists all of the fax numbers and e-mail addresses currently stored in the machine's memory.
    • [Send Report] - This report lists the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results for a particular fax job.
    • [Sent Report] - This report lists information about the faxes and e-mails that have recently been sent. The machine can be configured to automatically print this report every 50 communications.
    • [Fax RCV Report] - This report lists information about the faxes that have recently been received.
    • [Schedule Jobs] - This report lists the documents currently stored for delayed faxing, including the starting time and type of each operation.
    • [Junk Fax Report] - This report lists the fax numbers specified as "junk fax" numbers.
    • [Network Info.] - This report lists information about the machine's network connection and configuration.
    • [Network Auth List] - This list shows authorized users who are allowed to use the e-mail function.
  6. Press the [OK] button. "Print?" will be displayed.
  7. Press the [Left] or [Right] arrow button until "Yes" is displayed.
  8. Press the [OK] button to print the selected report.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=301,E=0000000000016129653,K=272,Sxi=4,Case=obj(2601)
Dec 18, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
I keep getting "image on fax send report is set to
Hi!!
Press the Setup button on the front panel of your All in One
Go to Print report
Check for Fax report it may be off turn it On
Apr 16, 2011 | HP Photosmart C7280 Printer
It will not scan instead it states it is not connected to the port, I tried several things including going through all the screen help supplied by Canon's website. it refuses to get out of fax report...
Try switching everything off, and on again.
Make sure you switch on the scanner before the computer.
If this fails, contact the manufacturer direct. They are usually quite helpful.
JR
Sep 29, 2009 | Canon PIXMA MX700 All-In-One InkJet...
We are getting a message "waiting on report" when trying to fax
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
May 29, 2009 | Canon PIXMA MX300 All-in-One Printer
Need to turn off report after every fax sent
Press [function] button and then [dataregistration] on the display dataregistration will be displayed,press [ok] user settings will be dislpayed,press the arrow down until you find report settings press [ok], tx report will be displayed,Press [ok] again.It will show on the screen "output yes",press the arrow untill it show "output no" and press [ok] again.
Thats it.
Apr 01, 2009 | Canon FAXPHONE L80 Laser
Canon mx700 fax report problems
Mar 05, 2009 | Canon MX700 Office All-In-One InkJet...
Solution:
Jan 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Hi how do I turn of tx and rx reports on faxcentre F110/
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
  • With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
  • Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
  • Always: a report is printed after each successful or interrupted transmission.
  • On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
  1. Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
  2. Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
  3. Press [OK]. The transmission report screen will be displayed.
  4. Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
    NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
  5. Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Dec 11, 2008 | Xerox FaxCentre F110 Plain Paper Laser
My canon mx310 wont allow me to send a fax, it says 'waiting for report' when i press send.
I have the solution for this problem. You need to go into your fax settings, and adjust the RX Settings. There is an option there to "print if no ink" and you set that to YES, and it will spit out the pending report that is preventing you from sending faxes.
May 25, 2008 | Office Equipment & Supplies
"waiting for report" /won't copy
Solution:
Apr 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX320 Color USB InkJet Printer Logo
448 people viewed this question
old marine
old marine
