Need to know how to reset after installing drum cartridge
  • 1,326 Answers
That all depends on what kind of copier you have??????
Posted on Sep 12, 2010
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
6.Press Options.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Hi, I have a Workcenter XD102. It gives me a J2 error. I don't know how to fix it. Please help. Thank you very much, Charles
J2 error for Workcenter XD102 indicates a Drum Cartridge Problem sensed by the main PWB indicating that the Drum cartridge had reached its end of life. You may replace the Drum cartridge with a brand new Drum Cartridge. This should fix the problem.
If you believe that its not the Drum cartridge with or without replacing the Drum cartridge, you may try to open the printer, make a good clean and perform the below. 1. Check the PWB and Drum Cartridge Reset Circuit for any loose connection and short circuit. You may re-seat the cables and terminations and test. 2. If that didn't work you might need to get some voltage from the Drum Cartridge Reset Circuit as per below. 2a. If voltage is more than 0.5 VDC measured between PJ CN116-2 and GND then you need to replace the Drum Cartridge Reset Switch PL x.x. 2b. If voltage is less than 0.5 VDC measured between PJ CN116-2 and GND then actuate the Drum cartridge Reset Switch. Then check the voltage if its +5 VDC measured between PJ CN116-2 and GND. i. If not then replace the Drum Cartridge Reset Switch PL 5.. ii. Else it should be fine. iii. If not then replace the Main PWB, PL 7.1.
Jul 12, 2011 | Xerox WorkCentre XD102 Printer
Drum replaced unit still says drum near end. How do we reset? We are not given an reset option
Try this:
If printer displays "Toner Life End" after installing new cartridge, open front cover, press 'Option' button, then key *00 on the keypad. This resets the device so it knows it has had a new cartridge.
this will reset toner counter on a lot of brother printers good luck.
or:
Open door
press Clear/Back key
press *00
press OK
Do not choose anything for drum replacement. when drum replacement menu comes up, just press the * and then 00, then just press OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 26, 2011 | Brother MFC-8660DN Network Mono Laser AIO...
I changed the drum but it still reads drum error and i am not receiving faxes. There is a ring so the connections are working. I cant get in to the area where it reads drum set.
Need to know Make and model to be sure.
However, many new machines reset the drum counter by blowing a fuse in the drum cartridge or by recoginition of a new chip in the cartridge. Some require a "Service code" access to reset counter after the drum has been replaced. Need specifics to be more help.
May 11, 2010 | Office Equipment & Supplies
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
Drum cartridge - generic
Sharpe are correct there is no known button sequence I know about as the drum normally has a resistor that blows when installed resetting the drum count.
Thanks J
Dec 26, 2007 | Sharp AL-1661CS All-In-One Laser Printer
DRUM REPLACEMENT CODE
How to Reset the “Replace Drum Cartridge Soon” Message on a Panasonic KX-FL511
[Menu]
[9000]
[*] (Will display P-SF)
[6722]
[Fax Start]
[Menu]
Nov 18, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
MURATEC F-520 ERROR CODE 04
This code relates to a Drum Cartridge Problem.
Check the cartridge is installed correctly or at least try another drum cartridge.
Oct 03, 2007 | Muratec F360 Plain Paper Laser Fax
15 people viewed this question
jasbo
jasbo
