Question about Philips 50PF9630A 50 in. Plasma Television
I have a 50" Philips plasma TV, model # 50PF9630A/37, this is what I have done so far. This TV started to turn off and on by itself, then it would have periods of interference like lines across the display, I updated the software as recommended by Philips and the unit got stuck in that screen display after I upgraded and it was not responding to any commands, I checked all components and voltages and I was told the SBB board was bad, I changed it for a brand new one and now everything works but I have no image, it is dark, it only flickers when it first is turn on.
  • Al Mendoza Sep 22, 2010
    Dear lady Winn: Thank you for posting a solution, I understand the problem with the SSB board, however, if I buy another one, it may be bad too, I am already down $100 and I hate to spend the money if that is not the problem. Now you mention the display panel? Are you talking about the 2 boards that handle the upper and lower display respectively?
    I tell you what, I have place the old SSB board back in the TV and the image is there, stuck in software update, it tells me the last time I updated the unit, (which in turn destroyed my TV). I believe it might be the power supply, let me know please.
    Thank you for your time
    Al
  • Philips Master
  • 5,138 Answers
The board you are talking about is it the SSB board?Which is the signal board,Problem now could lead back to the Display Panel, unless the board you replaced has a defect in it ! You should keep in mind that New does not mean it works.
Encompass Parts Distribution 1-800-638-3328
They have One in stock Price 137.49 (Ssb) small signal board for Display.
Posted on Sep 10, 2010
I have a 50" plasma Philips tv 50pfp5332d/37 it
Most Common problem is Bad Capacitors on the power supply board, they will be vented or swollen on Top. 1000uf 16v 2200uf 10v 3300uf 10v
Jun 25, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
Help philips 50pf9630a/37 no power remote or switch will not do anything but there is power getting from wall ( cord tested with voltmeter )is there reset or fuses and where are they located any help...
If you open the cover at the back of your tv you will see the ac input then you can see the fuse their, if made of glass you will see the filament, if cut and no burn mark just try to replace it,but if the whole glass is burned and cant see the filament of the fuse your regulator is shorted replace it.
Oct 23, 2010 | Philips 50PF9630A 50 in. Plasma Television
Half of my screen plasma TV 50" is black. What I have to do to fix it? plhilips plasma tv model 50PF7321D/37
Your Television problem on vertical section.
Solve: If you repair itself replace vertical IC or thoroughly resolder dry any components.
Jan 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Screen Issues
Looks like the gas needs sorting.Did something hit the screen?It looks like ink splotches does it?Bring it back to where you bought it if its still under guarantee otherwise it will be very expensive to get it fixed
Mar 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
has only one main board
has many sub bords supporting tat main board
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
PHILIPS 50PF9630A/37
Quick test of the plasma screen itself:
1) Turn on the TV
2) Try to bring up an on screen setup menu using the remote or buttons on the tv.
3) Does the menu appear? If so, the screen itself is ok.
If it doesn't come up you make have an issue with the screen itself. I am not sure it would be possible to set contrast and brightness settings such that the picture would completely disappear, but I suspect you should be seeing something on the screen just from having turned it on.
We also need to know more about what you have connected to the television. HD televisions typically have several inputs on them including HDMI, digital cable, VGA and component. Let's say for example you have PS3 connected via HDMI. You can tell the PS3 to send audio across the HDMI cable as well as video. You also have the option of running separate connections for your audio signal. It is the existence of these options that make it necessary to understand where and how you have things connected, very specifically.
Sep 17, 2008 | Philips 50PF9630A 50 in. Plasma Television
Philips 50 inch Plasma - no audio on occasion
Try swapping the HDMI cable. They occassionally fail.
Nov 21, 2007 | Philips 50PF9630A 50 in. Plasma Television
My plasma TV turns itself off and there's nothing I can do to get it come back on...
Firmware is avialable for download on the philips web site. The latest one that is the bundle of mutiple patches may not patch all the problems. Looks like it has to be applied indivdually.. -anil
Jul 11, 2007 | Philips 50PF9630A 50 in. Plasma Television
Open Questions:
Philips 50PF9630A 50 in. Plasma Television Logo
289 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
