How do I correct or what is a system file error
  • 2,973 Answers
Stephen, Is the system file error hampering your working. If no, then let it be and continue with your computing. If yes then you may have to reinstall Windows. Follow the link below to reinstall and save your data as well.
http://www.fixya.com/support/r4220510-saving_data_after_crashed_windows
Posted on Sep 09, 2010
Tip
How to display Errors found and Repairs made by CHKDSK
<b> <p>How to display Errors found and Repairs made by the CHKDSK Command<br /></b> The Chkdsk command is used to verify the integrity of a file system and is capable of correcting discrepancies in system data files. This command has been with us since DOS days and has been modified by Microsoft as required to meet the requirements of new operating and file systems as they evolved. <br /> If you execute the Chkdsk command from a command prompt without using the F (fix) switch, Chkdsk runs in the read-only mode. As Chkdsk runs its tests on the drive, it displays the results of these tests on the monitor screen and the test results remain there for you to read until you close the CMD box.<br /> However there are several drawbacks to running Chkdsk in the read-only mode, especially on an active NTFS volume (usually C:) <br /> 1. Chkdsk cannot make any corrections to the drive while in the read-only mode.<br /> 2. If Chkdsk encounters more than minor errors, it will not complete all of its tests.<br /> 3. If you are running Chkdsk in the read-only mode on the active partition, Chkdsk frequently reports disk corruption and other file system errors which do not exist. This happens when the system modifies the disk during the Chkdsk testing sequence.<br /> Considering the above, there is little to be gained by running Chkdsk in the read-only mode.<br /> You need to run Chkdsk/F at the command prompt to test the drive and to correct any errors found.. As soon as you make this entry the system responds with:<br /> "The type of file system is NTFS. Cannot lock current drive."<br /> "Chkdsk cannot run because the volume is in use by another process. Would you like this volume to be checked the next time the system restarts? (Y/N)."<br /> After you key in "Y" (followed by enter) and re-boot, the operating system starts to load and you are advised that a disk check has been scheduled and unless you cancel it, Chkdsk/F will start to run in a few seconds. (Actually the file being executed at this time is Autochk.exe). Chkdsk will run through its phases but it only displays the test results on the monitor screen for about 2 seconds before the screen clears and the operating system continues to load!<br /> If problems were found wiith the file system, you will not have time to read any messages regarding what they were or what actions were taken. If corrupted files and/or orphaned files/directories were detected you would most probably like to know about it and other problems found by Chkdsk. So how do you display the errors found and actions taken?<br /> The answer is that since running Chkdsk/F is a system event, the information is recorded in the System Event Log under application events. To read the log, Click on Start, Control Panel, Administrative Tools, Event Viewer and Application. Look for "Winlogon" in the Source column and double click on it. An Event Properties dialog box will open and display the log for you to read..<br /> Yavacotech.<br />
on Dec 09, 2010 | Computers & Internet
Tip
How to display Errors found and Repairs made CHKDSK
Yavacotech.
The sd card is not working and saying card error
Go in the camera options and format the card. If your camera does not have this option or it can't complete the format it means that :
Your card might not be formatted with the correct File System. Move your SD Card to a computer with card reader and Format with FAT32 File System the move it to camera. If the camera gives the same error, format the SD card with the NTFS file system the try again in your camera. If the SD card still don't work try FAT Fyle System.
Nov 10, 2010 | Canon Elura 90 Mini DV Digital Camcorder
RCINT FAILURE STRING TABLE ID NOT FOUND "46" AT LINE 236 problem on my pc
Try running system file checker. It scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Start, Run, "SFC /scannow"
The error you're referring to is most often caused by pieces of software, such as LogonStudio, replacing system files.
May 15, 2010 | Microsoft Windows XP Professional for PC
My problem is I have a printer and I cannot install it because the file wiafdrv.dll on windowsxp home editon cd-rom is needed an do not have one.
Do you have a Lexmark printer? I found this dll file and many of the comments about it relate to Lexmark printer issues. Click the below link and it will download your missing dll file. I searched for "wiafdrv.dll" and there were no hits for this dll, but there was one for the dll file "wiafbdrv.dll". Make sure before clicking the link below, that this is the correctly named dll file you need.
http://www.dll-files.com/dllindex/wiafbdrv.zip?0VFiP0aMgO
Extract this file and place the dll file in the correct location as specified by the error you're receiving.
Mar 04, 2009 | Computers & Internet
Cannot find regsvr.exe
Download and run this:
http://piyushlabs.googlepages.com/Heal_regsvr1.0.zip
BTW...it's a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
System Error &H80004005(-2147467259) error in ms2007 pro excel and word
to correct this pls follow this procedure:
-close the file or presentation then reopen it
-open the corrupted presentation then click save as on File menu
-in the save as , pls type list, click the ff format (*ppt)
-in the file name box, type the file name you want to use, then click ok
-close and reopen the presentation
hope this helps
Aug 08, 2008 | Microsoft Office Professional 2007 Full...
How to solve runtime error in visual c++ and abnormal programme termination in Internet explorer 7
Run System File Checker (SFC) to correct any problems with system files, do a full scan.
Click Start/ Run / then type SFC and press ENTER, to launch the SFC dialog box. Also try removing any toolbars you might have in IE.
Apr 05, 2008 | Microsoft Windows Vista Ultimate Edition
Getting a message about and error on page.
Dear Wendy,
This can happen because of multiple reason:
a) It isn't your fault. The file publisher has not correctly made pdf or its corrupt and won't work on your system because all pdf files can be opened in almost all versions.
b)You might like to check your adobe 8.1 settings for complete installation. Have you correctly installed the program. Also check if you are able to other pdf files on your system or not.
c) you can also try an older version of acrobat, which i doubt should affect the problem.
Finally check the file extensions and password protection problems.
If that was helpful please press solved.
Nov 14, 2007 | Adobe Acrobat 6.0 Professional for PC
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
