Question about Dell Inspiron 1525 Notebook
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings and it says the battery is charging and that the battery is performing normally. Is this a charger issue or a battery issue?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 29 Answers
Diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
Need New replacement Dell Inspirion 1525 battery replacement ?
Professional battery shop:
(UK)
http://www.global-battery.co.uk/laptop-batteries/dell-inspiron-1525.htm
(US)
http://www.sales-battery.com/laptop-batteries/dell-inspiron-1525.htm
If you need Universal laptop ac adapter
link:
http://www.global-battery.co.uk/Universallaptopacadapter.htm
Posted on Sep 29, 2010
  • 109 Answers
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Posted on Sep 09, 2010
I had to reinstall my vista os on my dell inspirion 1525 and now the wifi connection will no go on. I h ave tried turning on and off the toggle switch, the BIOS is set to enabled for wifi, I have tried...
There is a strong chance that the wireless card inside is bad. I work at a computer repair shop and work mainly with laptops. It isn't uncommon for wireless cards to go bad, before their "time". Usually Dell's have access panels on the bottom of the laptop where you can see the wireless card. It will have 2, sometimes 3 small wires plugged into it. Usually dell' use Dell brand cards, which are really repackaged Broadcom wireless cards in most cases. In your situation, write down what the model number is, go to another computer, look up that model on ebay, buy one, replace it.
Oct 04, 2011 | Dell Inspiron 1525 Laptop
Dell Inspirion 1525 will not boot up. Stays on the Dell screen. The laptop does not respond to F2, F8 or F12 keys.
Try this once...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
If there is no response please leave a feedback
Jun 22, 2011 | Dell Inspiron 1525 Notebook
The left side of my Dell Inspirion 1525 laptop is darker than the right side. Any ways to fix that?
Replace the LCD screen. Probably $120 to buy a "pre-owned" screen, or double-that for a new screen, plus $60 in "labour" for a qualified technician to do the work.
Oct 31, 2010 | Dell Inspiron 1525 Laptop
Dell inspirion 1525 will not boot upon power up...only displays locked 9 light solid
This is a Hard Drive error. If your unit is under one year old, you can get the drive replaced by Dell.
The drive can be accessed outside the laptop to retrieve the data, but it may fail all together very soon.
If you have no data on it, just get a new Hard drive installed. Dell should be able to replace the drive and start the system restore for you.
Mar 28, 2010 | Dell Computers & Internet
Locked out by password on dell inspirion 1525 how do i re install vista
If you have the vista disk, then just put it into the drive, and reboot. You may need to change bios boot order, which can be done by pressing f8 as the computer starts up, and selecting the dvd drive. If this does not work, then please refer to your user manual for the correct key to press. If you can boot, then the installation is self explanatory. Give it you country and keyboard layout, and then when the screen shows "install vista" button, undeneath it is a repair vista button link. Click this, and select your existing installation. From there it may ask you about "system restore" press cancel, and then hopefully, it will restore.  Hope this helps.
May 24, 2009 | Dell Inspiron 1525 Laptop Jet Black
My internal mic of dell inspiron 1525 is not working
my dell inspirion 1525 microphone is not working. when i am on yahoo messenger i hear the other person but they can't hear me unlike before i use to hear the othe person because there is an in built mic.
Mar 25, 2009 | Dell Inspiron 1501 Notebook
Buttons 3EDC not working what i can do?
MAJORITY of the time you'll have to replace the keyboard. It's almost always the cause.
You can find one on ebay for cheap and replace it yourself in about 5-10 minutes.
Best of luck!
Feb 26, 2009 | Microsoft Windows Vista Ultimate Edition
Load XP in Dell inspirion 1525
If U want to change ur pc's os to WinXp the go to dell.com and choose Ur country after that go click on the support link or support and driver link then choose ur laptop after that choose the operating combo box to winxp(sp2) and if there is driver's are available or not in most cases Every Dell laptop has xp(sp2) drivers............
Shubham.................
Jul 26, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
446 people viewed this question
Alun Cox
