Question about Nikon Coolpix 4600 Digital Camera
Haye, sir i m use of nikon coolpix 4600. but yesterday is problem have show in the screen system error 1 0. and no working camera so what's problem in the camera.plz solve the problem. thank you.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 09, 2010
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
System error 10
Nikon support made these suggestions:
1. insert the memory card that originally came with the camera (Nikon approved card).
If that doesn't help, then:
2. remove the camera batteries. Leave the batteries out for 24 hours. then replace them
If these suggestions don't resolve your problem, they say the camera must be sent to Nikon Service because there are no "user serviceable parts on the Nikon Coolpix cameras"
Feb 28, 2011 | Nikon Coolpix 4600 Digital Camera
How to solve system error 1 over 0.
Hello
When a System Error message appears on the LCD screen of the Nikon Coolpix 4600 this usually means the camera has a fault that will need repairing. There are two things you can try first. The first one is to try a different memory card. The second is to remove the batteries for 24 hours and then put them back in the camera and try again. If this does not work contact nearest Nikon Service Center.
Good Luck, do rate the solution if helps
Dec 07, 2010 | Nikon Coolpix 4600 Digital Camera
Nikon 4600 coolpix
Hello, Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 secondsthen replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
Dec 08, 2008 | Nikon Coolpix 4600 Digital Camera
System error showing up on Nikon coolpix 3200
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
Jun 13, 2008 | Nikon Coolpix 3200 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
System Error 1 0
Let me give you a little information about this issue. Nikon 4600, S1 and S3 have a faulty operating system. The good news is that there is an update for it. The process of repairing that issue might take an hour or two. You have to hard boot the camera with a jumper setting on the unit to force the new operating system in the camera and then upload all the updates.
Nikon is repairing them for people, but they want you to send it in and are charging people $87 for the repair. You might be able to find someone near you that can do the repair for you much cheaper.
It might just be better to buy a new camera.
Sorry i couldn't help more. Good luck.
Apr 08, 2008 | Nikon Coolpix 4600 Digital Camera
System Problem with Nikon Coolpix 4600
Is the card formatted? If not, format it in your phone, or via card reader hooked up to PC.
Apr 07, 2008 | Nikon Coolpix 4600 Digital Camera
System Error
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 26, 2007 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix 4600
i don't know what this means- it's more an error in the laptop I would think Can you still see images via the review control in the camera?
Feb 12, 2007 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
65 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
