Question about Cell Phones
Is there anything on the 9133i phone that can be used to reset to factory settings?
  • 712 Answers
Go to Settings. The last Option in that Menu is to Restore Factory Settings.
Cheers. Thank You.
Posted on Sep 09, 2010
How do iget passed google verifing acount2
In settings there should be option to factory reset, but there also should be an accounts field where you could remove the account and add yours, but to get rid of anything left behind from previous user the factory reset would be better option.
Feb 05, 2016 | Google Cell Phones
The red light on my Aastra phone 9133i does not blink when I have a voicemail message
Phone your provider and ask them to turn on the indicator light. If you hear beep beep beep when you have a message they have it set wrong. Tell them you have a red light on your phone. They just set it incorrectly . Happens all the time hope this helps
Oct 24, 2013 | Aastra Telecom 9116 Corded Phone
How to hard reset or format samsung SGH-A777 since my screen has gone white and i cant see anything :(
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (8)
  4. Highlight, using the navigation keys, any of the following:
    • All: Sound Profile, Display, Phone, Alarm and Bluetooth settings will be returned to default values
    • Sound Profile Settings: Only sound profile settings will be returned to default values
    • Display Settings: Only display settings will be returned to default values
    • Phone Settings: Only phone settings will be returned to default values
    • Alarms: Only alarm settings will be returned to default values
    • Bluetooth: Only Bluetooth settings will be returned to default values
  5. Press the a737%20center%20key%5b2%5d.jpg key to check the box(es) of the desired Reset Settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is "0000"
  8. Press the left soft key for OK
  9. If prompted, Enter the password again to confirm, using the keypad
  10. Press the left soft key for OK
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Jun 03, 2011 | Cell Phones
How do i do a master reset?
Performing a factory reset via settings The most convenient way to do a factory reset is via the phone settings.
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Ref: http://www.htc.com/www/howto.aspx?p_id=297&id=182
May 03, 2011 | HTC HD2 Smartphone
My cliq runs slow, it also drops calls, and I cannot access my text messages, I did start haveing this problem until I update my software from a 1.5 to a 2.1, how do I reset the phone to its factory...
Before doing anything you might regret afterwards you should consult your service provider and ask them about the issue. If you want to do a factory reset make sure you have backed everything up. Then go to settings -> sd & phone storage -> factory data reset.
More insturctions on factory reset: https://supportforums.motorola.com/message/73135
Apr 18, 2011 | Motorola Mobility CLIQ Cell Phone
The process com.android phone has stopped unexpectedly. please try again. This message comes up on 90 % of my incoming calls. Force close ? Any ideas Thanks
I would start with a Master Reset. That's the best place to start.
Pulling the battery doesn't really do anything but fix little problems.
Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press HOME > MENU, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the HOME, END CALL/POWER, and BACK buttons. The reset process will start after a few seconds
Mar 29, 2011 | HTC Hero Smartphone
My env3 takes about 8 to 10 seconds to load the messages menu, and load anything in that menu (such as starting a new text or opening texts). anything to help it?
Please try resetting the phone but this will reset the phone to factory default.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Open the flip and press OK [Menu].
  2. Press 9 or Settings & Tools.
  3. Press 6 or Phone Settings.
  4. Press 7 or Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Press 5 or Reset Default.
  7. Press OK after reading the warning message.
  8. Press OK to select Revert. A confirmation message is displayed briefly before the phone resets itself.
http://www.resetcellphone.com/solution/LG/vx9200-env3
Feb 22, 2011 | LG enV3 VX9200 Cell Phone
Is there anyway to change the name that is
It's part of the phone system, it's software. Find out who controls the phone system and get your name on it.
Nov 25, 2009 | TalkSwitch TS-9133i
Reset sciphone i68 to factory settings, now it won't do anything
I also have the same problem. I took the battery out and put it back again. I could unlock the phone. But everything in the phone is messed up. The "setting" icon is for radio, the "radio" icon is for "setting", etc.
Jul 21, 2009 | Cell Phones
Reset phone to factory
*BEFORE COMPLETING A HARD RESET, BACKUP ANYTHING YOU HAVE STORED ON THE HANDSET, THIS INCLUDES CONTACTS*
1. Select MENU
2. Select Settings
3. Select RESET SETTINGS
4. Select ALL
5. Press OK
6. Press Reset
7. Enter Password (default 00000000)
this was taken from mobilereviews.o2.co.uk
display_flip('id3190', 'divId3190');
May 02, 2009 | Samsung J700 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
