Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
When I connect the laptop does not recognize after format
I am trying to trasfer a large amount of files from my macbook to a dell laptop. The mac will recognize the drive and i am able to backup and save files onto it, however when i plug the drive into the...
The problem most likely is the Dell does not recognize the MAC file format (HPFS), but the MAC will recognize the PC's FAT 32 file system.
First format the USB mass storage device using the Dell, format this device in FAT 32 not in NTFS because the MAC can read and write/copy PC format files but the Dell/PC cannot read MAC format files.
Then Safely remove this device, connect it to the MAC and copy the files onto this drive. When you connect this device to the Dell, you will be able to see the files.
Have fun.
Aug 13, 2010 | Iomega Computers & Internet
USB Memory Key not Recognized on Desktop running Windows Vista
check the formats of the keys. if they are NTFS they might not be recognized by earlier Windows versions. What version of windows does the laptop computer use? It may be as simple as using the correct formatting (FAT or FAT32) on the USB memory key.
Sep 14, 2009 | Maxtor Hard Drive
I have an iomega exteranl hardrive whic i can access on my Mac laptop, but when i connect the drive to my my windows based laptop, it's not accessable
I not a big mac expert but it is probably to do with the way your portable drive is formatted. Windows pc's will recognize drives formatted as FAT32 or NTFS. Mac's will also recognize these formats. If the disk was originally formatted with a mac format like HFS is won't be recognisable to windows. Connect it to your mack and look for the Fike System Type. You could back up any files you have on the portabe device to your mac hard drive then format the drive on a windows machine. Start with a NTFS partition and see if your mac can read and write files to it. If not then try again with fa32. Once you have it going you can put your saved files back. Hope this helps. Let me know how you go.
Jul 23, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have inspiron 1501, can the driver play dvd 9 ?
Your laptop has a built in dvd-rw so it can definitely recognize the dvd 9 format. Any dvd-rw can recognize that format regardless of the laptop or desktop computers.
May 15, 2009 | Dell Inspiron 1501 Notebook
PHYSICAL IP ADDRESS NOT RECOGNIZED, IT JUST SAYS FF-FF-FF-FF, AND DOESN´T RECOGNIZED THE IP ADDFRESS FOR THE INTERNET CONNECTION?? PLEASE HELP, DO I HAVE TO FORMAT MY COMPUTER OR I JUST NEED A DRIVER?
Update the O/S first
Check the connection is DHCP
control panel,network connections, right click your connection to the internet, properties,
TCP/IP VER4, highlight this in grey, click properties,
should be set to
( obtain I.P. automatically ) tick this box.save it.
Reboot the system.
hope this helps
Regards
Apr 19, 2009 | Toshiba Tecra M2V-S310 Notebook
Vista (32) will not recognize my lacie d2 external harddisk
solved: after referring to the userguide, I found that I formated my drive with a OS format, which can not be recognized by VISTA >> formated to FAT32 and now it works...
Jan 03, 2009 | LaCie d2 Extreme 250GB External with...
My laptop does not recognize the hard disk after formatting;
Actually, have you tried running the Windows install yet? When you're in Windows Setup, it should recognize the hard drive as a device, even if it's not formatted or formatted properly.
Try going into the BIOS for the laptop (it might be called Setup Menu or some such - you should see a prompt for hitting a key like Del to get there) and look and see if the BIOS recognizes the hard drive. If the BIOS doesn't see the hard drive, then the problem might be with the laptop and not the hard drive.
Dec 29, 2008 | IBM ThinkPad R31 2656 Notebook
Hard drive not being recognized
my book world is a network drive, you should connect it to a router / switch using an ethernet cable. if you use a usb cable to get it recognized on your computer it will never work
Aug 24, 2008 | Western Digital 500GB My Book World...
Can not access my hard disk
It would be a good idea to run a anti spyware and anti virus to check the drive.
Thanks
Aug 22, 2008 | Computers & Internet
2GB SD card no recognized
sir probably your 2gb is dead or not factory formatted... just take your receipts and take that back to where you bought it... if it is formatted probably its the same problems of those who formatted their SD with windows xp... that worsen your problem cause i think you just void the warranty of your SD card... try your SD to other card readers and if something pops like "your drive is not formatted... format i now... just click no"
Jan 20, 2008 | HP Compaq nx5000 Notebook
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
32 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
