After turning the copier on there is a message on the screen that states "A misfeed has occurred" An arow points to the document feeder on top of the scanning glass and gives step by step instructions on how to clear the misfeed. There is no misfeed and no paper jammed inside the document feeder The copier will not work at all until the error is cleared
  • 17,970 Answers
This chapter explains what to do when a paper misfeed occurs in the machine, clikc in the LINK and check the procedure in the page 5 and next: Sharp-Troubleshooting
Hope helps.
Posted on Sep 09, 2010
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
Sharp AR-M237 a misfeed has occurred, top feeder. there is no paper have did as the information states and still will not clear.
Is the jam indicated inside the copier or on the document feeder that scans the paper across the glass ?
Mar 19, 2011 | Sharp AR-M237 Copier
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Copier Sharp AR-M237 a Misfeed Occurred message
    First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
    Mar 24, 2010 | Kyocera CopyStar CS-3060 Black and White...
    I have a Canon Image Runner 3230 which we also use to scan PDF files into our snap drive. When scanning a large job build, if the machine jams, the documents already scanned in the job build are lost. Is...
    Hi mail. Let me tell you a workaround for this problem.First of all I understand every aspect of your question and problems as the document feeder for the ir 3220 is about the biggest piece of **** I've ever seen and I have been working on copiers since 1988.And when you use the "Universal "SEND" " function I also realize that for example if you have scanned a 500 page document and it jams at 499 you have to start all over again.That because the copier has established communication with the server directly during the "send" process and when an error {document paper jam} occurs, for whatever reason the error cannot be reconciled on the fly. BUT!!!!! :-) If you scan the same document(s) to the "Mailbox" function the copier can and will allow you to recover from such a mishap as the process you are conducting is all happening "on board" the device so if a jam or misfeed occurs in the document feeder during the scanning process the copier will tell you to put the stack of originals back in the feeder with page 1 on top.Then the copier will begin to feed the originals quickly merely to count the pages till it finds the the one it jammed on.Once it counts to the original it failed on it will resume the scanning process.THEN...... no matter how many failures have occurred during the process, once you are done the "SEND" function will appear as an option.At this point you will be viewing the "batches " of documents in the display because if it is a large document you will not have been able to put the entire bulk in the feeder at once.Now highlite all of the"files/batches" and hit EDIT. Under edit will be the "merge" option. Select merge and all the batches you have highlighted will be merged together into one big document.NOW selest SEND and designate the location you wish to send it to.Since the document in its entirety resides correctly in a "mailbox/hardrive" storage area it can be sent with no fear.I have many customers with this same difficulty and this has been a lifsaver. hope this help,and have a better day! :-)
    Feb 10, 2010 | Canon imageRUNNER C3200 Copier
    Misfeed detected but no paper jam
    Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
    for the image unit try this site
    Precision Roller Printer Toner Cartridges Parts and Supplies Office...
    as for the adf replace!!! the rollers all three try the same site above
    Nov 03, 2009 | Minolta Di251 All-In-One Printer
    Documents will not feed from the ADF
    Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
    Jul 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
    jasbo
    jasbo
