Question about Cameras
I get a format error with a rapid flashing Memory Card symbol and a flashing C:13:01 every time I turn on my camera. I don't want to try to reformat becuase I have some good pictures on the card. What can I do?
  • 6,831 Answers
Hello
OK, i fully understand the problem, with being a photographer myself.
At the link below you will be able to get a couple of suggestions on the problem, if none of them work, let me know, so we can figure out something else.
Click HERE.
Kind regards
Andrea
Posted on Sep 09, 2010
Lost all memory on a 64gb sd micro card after formatting
No, you didn't loose memory. You just have to reformat it. When you do, check if you can change the total capacity with drop down menu, also try settings it to FAT32.
If not, you could use another computer or even a portable device like cellphone or camera to try and format it.
Don't worry, you cannot 'loose' the 64gb.
Jun 19, 2012 | SanDisk Electronics - Others
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
Camera syas ``Error Formatting Menory Stick`` (2GB Menory Stick ProDuo Card) What can I do to format the card?
try using a pc with card reader / writer to format the memory stick pro duo and then try it again in camera it should work........If you have troubles formatting the same using a PC as well check if gets detected as removable disk and then try using a antivirus to scan it and if you find any virus, remove it first and then format it. it should then work.............
Aug 11, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Sony memory stick PRO duo 4gb card says memory full when empty
I would suggest formating the memory card through the options on your camera. If you reformat the memory card and you still get the same error then you have a bad card. Just like anything else the cards will break down internally over time.
Mar 07, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Memerory card error
the memory card may need to be reformatted. if you have an external card reader, plug it in, right click (in windows) and select format.
you might be able to format it through the camera if you don't have a memory card. connect the camera to the computer, and treat it like an external card reader.
if reformatting doesn't work, sounds like the card went bad.
Oct 22, 2009 | Canon PowerShot A75 Digital Camera
Can only take about 5 photos at a time and then only after reformatting the memory card.  After about 5, I get one of two error messages "camera cannot display image" when I try to playback or "memory card...
The card may be done. Thay have a limited lifetime, and if it was a cheap card in the first place.......
Reformatting does not fix this, the formatting software will scan for bad sections of the card and exclude them form the format.
It could be that there is a problem with formatting from the camera. But a card reader to fit to the PC and download the card formatting program from the official SD standards website. If your card can be properly formatted then this will do it.
Nov 29, 2008 | Pentax K20D Digital Camera
How do i reformat a sandisk 2GB microSD card. keeps saying failed
Are you formatting it in a cell phone, a digital camera, or on your computer?
If you're formatting on a computer, be sure you have the microcard inserted into the adapter correctly. I would suggest you format the card in the device that you're using it in most.
Nov 19, 2008 | SanDisk 2GB microSD Memory Card
Memory card won't format
Most likely one of the pins on the compact flash connector is bent, not allowing the card to be recongnized correctly - Am now fixing such a problem for a friend
Jan 23, 2007 | Canon PowerShot A95 Digital Camera
Memory card error
The problem seems to be that the card has been formatted incorrectly (probably by your computer, if you used it in a card reader?). Unfortunately the camera can't reformat it itself, and default computer formatting is incompatible. You'll want to download the program Lowlevelformat.exe from this website--http://olypan.quotaless.com/forum/viewtopic.php?t=8, install it, reformat your memory card with it, and the camera will be happy with it again.
Oct 01, 2006 | Olympus Camedia Stylus 300 Digital Camera
Cameras Logo
50 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
