Question about Garden
I want to know what type of diode shall I use to my 12volt battery charger
Try a zennier current limitting diode that allows current only to flow one way. The charger should have a max. current posted on a tag somewhere on charger
Posted on Sep 09, 2010
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
Feb 27, 2016 | Cub Cadet Garden
I WANT TO CONVERT MY SCOOTER FROM 36 VOLT TO 12 VOLT HOW CAN i CHANGE MY 36 V. CHARGER TP 12 VOLT
This will need a motor change as well which is a pity and pressume that you have looked into that already.
Simply if you already have 3 12volt batteries you can charge in series and use just one in scooter or you can purchase a ordinary car 12volt charger for a cheap price an there are advanced units that give good deep charge automatically
Nov 07, 2014 | Health & Beauty
Easynote tj75
Probably a bad processor.... Or the motherboard has a few Diodes that are bad
Aug 06, 2013 | HP Computers & Internet
I have a B&D Firestorm 18v 1-hour battery charger, model 5100235-09 (240v). When I insert a battery to charge, only the green "battery full" LED lights immediately. But the battery never...
Hi I have same problem with the charger. Solution is to replace the charge with new part number issued from B&D Australia
Number of 90515050-01 until stock runs out , then it is replaced by part number of 90578873 early to mid june 2013.
Hope this helps
Lance from Perth , Western Australia.
Jun 19, 2011 | Black & Decker Drills
How do I know if my battery is bad or if my charger is bad? The red light on my charger no longer lights up when I plug it in. This is for my Black & Decker Firestorm 12volt drill. Thanks
With a multimeter set it to 12 volt dc and place the leads on the two parts that would be touching the battery. If you see voltage then it is a bad battery.
-David
Nov 08, 2010 | Black & Decker Black And Decker 12 Volt...
How do i know if the battery is fully charged 12volt peg Perego battery
the charger's L.E.D. ... when plugged to the charger will glow GREEN if fully charged, YELLOW if charging, if it is charged and gator still is not working it is probably the shifter switch is bad, this is verycommon and fairly cheap and easy to fix(under 40.00)
Oct 26, 2010 | Peg Perego John Deere Gator HPX Ride on...
How can I get a manual for the Hoverround MPV5?
If the power chair was stored for a while, the batteries may have gone bad. There is a gel inside them that needs to be put on a current regularly or it will solidify. When you connect the charger, you get a green light because it senses the batteries are full; unfortunately they are full of crud, not power. Try replacing the batteries to see if that solves the issue. You can probably take them to an auto parts store or Interstate Batteries to have them volt tested. The type of battery you need is a U1, 12volt, 33amp and you will need 2 of them.
Apr 29, 2010 | NRS Hoveround MPV 5 - Used Power...
Hi, I have a motorizr Z3 phone whose charger failed. I have run out of warranty and hence I went to a store and the guy gave me another Motorola Charger that is of 6.5 Volts. My original charger was of 5.0...
hi, you need to get the same charger if the output is to high then the phone wont put the charge into the battery as it could cause it to over heat, the best place to buy one from would be the well known online auction site you should get one from their for next to nothing and this will then solve the problem.
You know the battery is not at fault as it charges from your computer via the usb lead however the charger you have brought should still charger the battery but may cause it to over heat so to me it seems like their is a fault with the new charger. Its always best to buy the exact type of charger you had in the first place as this ensures the battery is charged properly.
What phone makers do is keep the same charge connector across most of their range of phone but as phones and technology changes they start using different batteries in their phone so they have to change the charging power to match the phones battery, so the charger you have brought is probably for a newer phone with a higher voltage battery, so you need to get the correct type of charger and this will then solve your problem.
Or if you have a car you could buy a car charger as these charge the phone alot quicker as they run off 12volt so put out more amps to the phone but keeping the volts at the correct type.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
Need to increase voltage on powersuply
Hi John.
No idea why your post is under monitor problems ???
I figured you need an adapter mod for a monitor !! SO don't kill my ratings since this is not my area of expertise, but I can try to give you some input anyway, not so much a solution !!.
I would NOT recommend altering a 12 volt adapter for charging a battery especially if it is a standard ac adapter.. You may get it to give you 13.8, but your amps may be wrong.
Battery charger depends on type of battery also. Don't know if you are using NIMH or Nicad or acid based ?
The differnt style batteries use different type chargers. Wrong charger will burn up a battery or blow it up !!
If the battery is a 13.8 then normaly the charger would be putting out 2+- volts more than the battery rating. If you battery is 12 then a 13.8-14 would do the trick. (12 volt car batteries for instance take a 14+ volt source to charge them)
I would recommend looking here
http://www.powerstream.com
They have all those goodies and may give you an idea. for what I think you are doing.
Fran
Oct 17, 2008 | Computers & Internet
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
