Question about Kodak EasyShare V1003 Digital Camera
When i turn my camera on, the objective-lens is not fully open and in a same time make a sound simuilar to crunch.. and the objectiv can,t fully close.. so maybe can you help me to understand what's hapening? thanks!
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 09, 2010
Download and picture mode inversed
is depend of the model, check usb mass storage or tell me the model and brand .
Oct 27, 2017 | Pentax Optio S30 Digital Camera
My camera lens doesnt open fully for pic and screen is blurry,I tried to Zoom and it shuts down. should I send to get serviced?
You could get it fixed. If you hear a crunching noise when the lens tries to open the gears are chewed up. If thats the case usually to expencive to repair. You could try to pull the lens out manually with your hand. Sometimes that will free up the lens. Hope this helps.
May 25, 2011 | Polaroid i633 Digital Camera
My samsung pl100 wont turn on. the lens is extended and its fully charged the green light comes on then beeps and shuts off. This camera is brand new ive only had it 1 week! how do i fix it?
OK this might sound harsh but i just did this. I pushed in, gently with some force, on the lens while pushing the power button. It made a gawd awful crunch sound, but it worked. Good luck.
Dec 23, 2010 | Samsung SL202 Digital Camera
My camera says lens error and to restart it? I don't know how to do that. It is a canon elph SD600
You can try turning it off and back on a few times, maybe even remove the battery for awhile. If the lens is physically damaged or dirty inside the assembly / gears, it would actually need servicing to fix this. You'll likely need to look for a repair shop, a great one and probably the most popular for these Canon Powershot cameras is camerasandparts.com as they only work on the powershots. They tend to be the place if you need help with a canon powershot camera. They don't charge much at all and they do all of the service on the camera too. Go to that site and you'll see they have your specific lens error problem posted right there for your SD600. Good luck taking care of it, that's a very nice Canon camera model.
Oct 21, 2009 | Cameras
Lense won't extend. Has error screen that says "lense error, restart camera"
sounds drastic but turn on cam and grab hold of lens to try to fully extend it manually. if you hear a crunching noise that means the gears are stripped. not worth repairing
Jul 09, 2009 | Canon PowerShot SD600 Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Lens does not come out anymore- crunching sound!
Sounds like there might be some kind of lens damage. If you call Casio repair center they may be able to give you a ballpark figure on what it would cost to send it in and have it fixed. The way you described it sounds like what they call a "lens error". Give them a call at 800-706-2534 and then keep choosing option 1.
Jul 24, 2007 | Casio Exilim EX-S500 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
27 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
